Convoy designed me (us) a hunting flashlight (L21B)
75 posts / 0 new
Funtastic
Funtastic's picture
Last seen: 51 min 52 sec ago
Hi all,
I have my own flashlight business here in New Zealand and my main market is hunting. I’m needing a mountable flashlight host with as large a reflector as possible for the best range using the Osram leds. It needs to be as light as possible so it’s not too heavy when mounted on the rifle.
Currently Maxtoch is the best seller here, but if I can get something with a decent diameter reflector, I can compete for a fraction of the price.
I’m currently selling both the Convoy C8+ and L21A and they’ve been very popular with the Osram CSLNM1.TG but unable to mount the L21A as it’s too heavy.
This would be made by Convoy
Any help is appreciated. I’m just no good at coming up with ideas or a design.
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
Edited by: Funtastic on 06/13/2021 - 08:22
pinkpanda3310
pinkpanda3310's picture
Last seen: 2 days 14 hours ago
Big reflector usually means extra weight. Eagletac m25c turbo has a small body to head (reflector) ratio. You can get those reflectors at kaidomain. However if weight is that much of an issue look for a plastic reflector like what’s in a fenix tk61
yasenf
Last seen: 8 hours 10 min ago
Hi, I also have small business with Convoy to hunters and have been bugged for some time with the same thoughts. May be look close to Olight M2X design – 18650 light with 60-65 mm head, very thin bezel, but big cooling fins, quality reflector. M2X without battery is 209 g. Eventually if he manages to make a thin body tube – 25-26 mm, he will be able to fit 21700 still in the standard 24-27 mm mount. If possible 22 mm driver (the new 8A will help a lot). Remote switch for this light will also be essential, in my opinion 2A USB charging in the threads will also be beneficial. I will be also buying this light for my customers, lets keep in touch.
kennybobby
kennybobby's picture
Last seen: 1 hour 3 min ago
i don’t know anything about it but curious:
What kind of hunting occurs at night—is it safe to shoot a rifle at night?
what about a missed shot how far could the round travel? Is it a concern that it might hit something you can’t see?
Just wondering.
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
arek98
Last seen: 1 day 40 min ago
Maybe something like Acebeam L17
Simon Mao
Simon Mao's picture
Last seen: 1 hour 4 min ago
I want to reduce weight based on the shape of the L21A. I will communicate with the manufacturer.
Funtastic
Funtastic's picture
Hi Simon,
That would be great. I actually found a mount that will fit a flashlight up to 30mm so that would work out well. The L21A host is easy to modify which is what I ideally want.
Simon Mao
Simon Mao's picture
Funtastic wrote:
Hi Simon,
I will post the design drawings here tomorrow for your reference.
i recommend KW CSLPM1.TG and KW CULPM1.TG for L21A.
i will get 8A driver for KW CULPM1.TG sample tomorrow
Funtastic
Funtastic's picture
I think to pull this off would require a large interest list or a large order from myself to get it made.
I asked Sofirn in April and they quoted a minimum of 150pcs
I’m not exactly after a compete flashlight, but a host to install a variety of leds and drivers. At the moment I’m using the Osram CSLNM1.TG white, green, red and plan to use the new CULPM1.TG. All of these require a different current
If it had built in charging I wouldn’t be able to achieve the above unless each driver was properly made for it.
I appreciate the input but our needs are a little different, although it would be a nice light.
Funtastic
Funtastic's picture
Just wondering.
We go pig hunting a lot at night as that’s when they come out to feed. Currently have a large issue of pigs eating new born lambs. We can’t use dogs in the day time since ewe’s will run away from their lambs.
A lot go deer hunting and there’s possum and rabbit hunting as well
You’d never shoot over a hill or out into an area that you’re unfamiliar with. When I go out I try make sure I’m shooting at an angle where it’ll hit the ground within my line of sight.
Funtastic
Funtastic's picture
Simon Mao wrote:
Funtastic wrote:
Hi Simon,
I really appreciate it.
If you can get the weight reduced of the L21A then it would be an excellent addition to my hunting range.
The Convoy L21A is already an excellent model for a handheld use
Funtastic
Funtastic's picture
Nice job on the Convoy Z1. I just received my order yesterday and I absolutely love it. I’ll purchase another 10pcs or so with my next order.
Sirius9
Sirius9's picture
Last seen: 1 week 17 hours ago
One of the problems on L21A is battery tube diameter of 30 mm, battery tube wall is about 4 mm thick, a lot of material there.
On other hand at thinnest part Z1 is about 26mm and it also fits 21700, just like the L21A.
For comparison C8+ battery tube is 25.2mm so I think 26mm is more than adequate for L21A as well.
If we say that 21700 is 22mm thick (with some room for those with thick wrappers) that would make 2 mm wall thicknes.
Btw. weight of the C8 and C8+ battery tube is 30 grams and for L21A is 54 grams.
kennybobby
Funtastic wrote:
We go pig hunting a lot at night…
Thank you, i’ve heard that the rabbit population is out of control, think i saw a tv story where they were out with sticks and clubs to thin out the herd.
Simon Mao
Simon Mao's picture
The original weight of the L21A is 366g (without batteries). After being lightened, the weight is within 210g (without batteries), and the appearance has become much simpler.
Funtastic
Funtastic's picture
Thanks Simon
That’s much better at 210g, I was expecting more than that. I’d certainly be happy with that for the Osram range
What’s the MOQ to get that made? I’ll send through an email tomorrow since it’s 3:30am here, I better get to sleep. I’ve been out for the last 2 hours taking photos of the M2 with SST40, Z1, C8+ for my website.
Simon Mao
Simon Mao's picture
Funtastic wrote:
Thanks Simon
I’m ready to produce 1000pcs (first batch) for sale ,
You don’t have to worry about the minimum order quantity,I plan to produce this flashlight for the hunting market for a long time.
Funtastic
Funtastic's picture
Simon Mao wrote:
Funtastic wrote:
Thanks Simon
Awesome, that’s wonderful.
Reading the first sentence of 1000pcs, I was thinking “well, I can’t afford that!….oh well” haha
I’ll certainly be ordering a good amount when they’re ready.
Thank you Thumbs Up
Zappaman
Zappaman's picture
Last seen: 1 week 3 days ago
The weight looks very nice here. But the head diameter concerns me.
One thing I have learned about (white, rifle mounted) “hunting” lights is that I can mount several “stock” (or host modified) lights to give me what I need for the hunt.
For pig hunting in most of my world (several ranches mostly in Texas), most kills are made within 50-150 yards and I need decent flood/spill to track and lead the shots for pig #2 and pig #3 (if I’m lucky) Big Smile Run times aren’t as much of an issue— as other lights (and night vision) are used to get to a field and find the pigs in range- then the WHITE light on the gun comes on and the action begins and ends within minutes. So my Sofirn C8F (old 18650) direct drive lights ROCK for anything within 225 yards or so.
For coyote hunting, sniper style- I’m guessing something like this light will be a LONG thrower and work great for that. But for most critters Funtastic is listing, I’d elect for a smaller over-all light where heat isn’t an issue even if you have to run it for more than a minute or two (as it’s not in the hand). I ALSO feel the Sofirn C8G is going to make a nice longer-range, throw light on my rifle this winter- for coyotes (as Kansas JUST passed a NEW law, finally allowing lights for coyote hunts at night Evil Usually we hunt them with full moons on snow where a good scope easily allows longer shots, but now a light like THIS one might be in order for the 300 yd plus shots.
I wonder when someone will start using a FET switch (like Lexel’s- that I use ALWAYS) as standard equipment? The current loss on ALL pressure switches WAS my problem up ‘till the last few years. Problem solved after finding Lexel here- how I ended up on BLF actually! Thumbs Up
ZappaMan
Funtastic
Funtastic's picture
Hi Zappaman,
Thanks for your input.
I stock quite a range a lights for everything but deer at 400+ meters, this is where Maxtoch beats everything I have, that I can mount, and is why I’m needing something much longer range than the C8 diameter.
I sell the C8+ and L21A with the Osram CSLNM1.TG but the L21A is too heavy and bulky to be mounted.
If you click on my website in my sig you can see that I have everything covered except long range. I get 350-400m of usable lighting out of the Osram C8+ but it’s not enough for what hunters are demanding
One of my customers said for deer 600+ meters is what’s needed and the L21A gets that but can’t be mounted.
This new design would be popular for New Zealand and I’ll be ordering approx 100pcs once they’re ready.
Funtastic
Funtastic's picture
Don’t get it with its 30 second timer on Turbo unless you are happy to continuously be double clicking.
Zappaman
Zappaman's picture
Yes, but my hunts are (always) over in a few shots- so 30 seconds is plenty of time. I LIKE that the C8G driver does hold its highest ramp point in it’s memory too (thought it WAS turbo?). I don’t like that one of my three C8G’s “rings” though. If they sell a host for it (like the C8F), I’d probably by a Lexel driver I can select a single mode on.
What was cool about my old C8F hosts (18650s) is that they went right into 1” scope ring mounts, and one high drain battery could run the three LEDs direct driven on some 18g leads- so no driver needed. I built FIVE of those the last 2 1/2 years and run 25Rs or 20S’s in them. The C8G “concept” is still experimental… I need to built the FET tail switch for the pressure switch Lan sent me last month. But my 125 tomato plants (twin vines per plant/now 8-9 ft tall on twine) is kicking off 200+ lbs a week— so I’ve been busy with that!
ZappaMan
Zappaman
Zappaman's picture
So you can hunt deer at night? – cool!!! We go to jail if we do that Sad
My 260ai caliber custom rifle can make an ethical kill at 600 yards on a still deer… on a still day… off a still (and solid) rest Big Smile But now the Creedmore can also do that with better factory ammo as of late— so I get you have these hunters needing super range.
My use for your light here would be on a coyote across a 1/2 mile long field. It would be on a high power rifle since the typical AR-15 platform doesn’t work at that range (it can’t deliver the required ft/lbs. needed at the deer). It would be mounted to the bottom of the forestock (never the barrel). But as coyotes are plenty fun to pop at 300 yards (and that and pigs are all I can hunt at night), I’d probably BUY this light- but not use it for hunting.
I’d LOVE to live and hunt in your great country! But I am cheap re. paying for guides when I can hang out on public land for long enough and “kill my own” thank you ;). The “pros and cons” of living on ranches 1/2 my life Silly
ZappaMan
pennzy
pennzy's picture
My question is why hunt deer at those ranges day or night. Around here they practically knock on your door.
Lightbringer
Lightbringer's picture
Last seen: 5 hours 40 min ago
Hey, they do that…
pennzy
pennzy's picture
Probably rut season. You been messing with my woman. Either come out or I’m coming in.
Lightbringer
Or he could be a Jehovie…
Funtastic
Funtastic's picture
For clarification they’re going to be used for searching as well. I’ll have a quick release mount installed on the rifle
It’s better to have the extra distance so it’s brighter at a closer range
At the moment I have a mount for the Astrolux FT03 but it’s quite bulky
Zappaman
Zappaman's picture
In West Texas I once saw a man shoot a deer at 1200 yards with a 7mm Weatherby Mag. That guy never left the ranch his whole life Big Smile
I’ve shoot a handful out over 600 yards or so. Out west, average shots start about 150 yards and 350 is considered a long shot. But with a very good scope on enough rifle (using hand loads we develop JUST for that rifle), getting out past 500 is repeatable given no wind. Some of us can also dail windage (or hold for wind with practice) and if it’s steady and pretty slow still, we can hit a deer at 500 pretty regular.
But never shot one on my front doorstep yet Wink
ZappaMan
pennzy
pennzy's picture
A lot less dragging when shot from the front porch Thumbs Up Shots around here are under 100 yards unless you set up on some farm fields and then maybe 150 yards. Most hunt from tree stands so it could be shorter even. Although most use more modern rounds, not too long ago 30-30s were still common.Those long range shots out west amaze me. A guy I used to know went out west, I forget the state, shot a elk across a canyon with a 264 Win Mag. He used to practice on chucks around here at some crazy distances. My hunting days are over but if I needed meat it would be out the window with a 22lr to the head.
Zappaman
Zappaman's picture
Thumbs Up
Couldn’t agree more, I love headshots- NO meat loss! Then you just need a sharp knife Big Smile
…oh and ya, uh… maybe an SP40 or my super old floppy-ass C8 headlamp— to see where you need to after the kill. Silly
ZappaMan
