✌ FREEME - ASTROLUX FT03 Mini XHP50.2 (4200lm) / SST40 Anduril AUX LEDs USB-C 18650 Flashlight - ALIVE
Full copper still happening? Interested!
Ok, NM1 = W1. Put me down for 1 as interested!
Note the more simple driver. Not a problem, just mentioning.
That was my thought exactly!
Interested
FT03 Mini NM.1
https://www.banggood.com/Astrolux-FT03-MINI-NM1-LED-5-Colors-510lm-860m-Long-Thrower-Strong-Beam-Outdoor-Searching-LED-Flashlight-Type-C-Rechargeable-18650-18350-Mini-Torch-p-1735877.html?rmmds=search&ID=2236294322&cur_warehouse=CN
Interested. Could I get the coupon?
Interested. Are there any other lights with the nm1 I could look at to get an idea of what its about?
There is the Wainlight C8+ with Osram NM1 LED, this is very similar to other C8 flashlights, but produces a more focused (more throwy) beam, but less total light output.
left:Convoy C8+ with XPL-Hi LED
right: Wainlight C8+ with Osram NM1 LED
Osram NM1 LED has a very tiny light emitting portion (the yellow square)
left: Convoy C8+ with XPL-Hi
Osram NM1 lights up a smaller area but more intense (throws farther).
I suspect the FT03-Mini with Osram NM1 will have similar throw (or a bit better) as the Wainlight C8+ with Osram NM1, but with better user interface.
Also the Osram NM1 LED on the Wainlight C8+ only uses up to 2.8 Amps max power, not yet maximizing the Osram's potential. Hopefully the FT03-Mini will better optimize the power (maybe like 4.5 Amps of power applied to the Osram LED), and also have a well-focused reflector.
def interested in a nm.1
interested blue one
Colored mini just became available on BG
Group buy is ALIVE now.
@freeme
Can you confirm what djozz asked before?
Ordered a blue one.
Regulated driver at max 4.8A. Lights will undergo 24hrs test before shipping.
Ordered a green on green
Is this the same driver that is in the Noctigon KR1?
Anyone know how much this thing throws? BG product page says 860m but is it true (white LED)?
Apparently this light does not have Anduril. No AUX LEDs either.
What is the colour temp for the orange one? 2500K? Is it good as fog light?
