That would be great. I actually found a mount that will fit a flashlight up to 30mm so that would work out well. The L21A host is easy to modify which is what I ideally want.
I think to pull this off would require a large interest list or a large order from myself to get it made.
I asked Sofirn in April and they quoted a minimum of 150pcs
I’m not exactly after a compete flashlight, but a host to install a variety of leds and drivers. At the moment I’m using the Osram CSLNM1.TG white, green, red and plan to use the new CULPM1.TG. All of these require a different current
If it had built in charging I wouldn’t be able to achieve the above unless each driver was properly made for it.
I appreciate the input but our needs are a little different, although it would be a nice light.
We go pig hunting a lot at night as that’s when they come out to feed. Currently have a large issue of pigs eating new born lambs. We can’t use dogs in the day time since ewe’s will run away from their lambs.
A lot go deer hunting and there’s possum and rabbit hunting as well
You’d never shoot over a hill or out into an area that you’re unfamiliar with. When I go out I try make sure I’m shooting at an angle where it’ll hit the ground within my line of sight.
One of the problems on L21A is battery tube diameter of 30 mm, battery tube wall is about 4 mm thick, a lot of material there.
On other hand at thinnest part Z1 is about 26mm and it also fits 21700, just like the L21A.
For comparison C8+ battery tube is 25.2mm so I think 26mm is more than adequate for L21A as well.
If we say that 21700 is 22mm thick (with some room for those with thick wrappers) that would make 2 mm wall thicknes.
Btw. weight of the C8 and C8+ battery tube is 30 grams and for L21A is 54 grams.
Thank you, i’ve heard that the rabbit population is out of control, think i saw a tv story where they were out with sticks and clubs to thin out the herd.
The original weight of the L21A is 366g (without batteries). After being lightened, the weight is within 210g (without batteries), and the appearance has become much simpler.
That’s much better at 210g, I was expecting more than that. I’d certainly be happy with that for the Osram range
What’s the MOQ to get that made? I’ll send through an email tomorrow since it’s 3:30am here, I better get to sleep. I’ve been out for the last 2 hours taking photos of the M2 with SST40, Z1, C8+ for my website.
I’m ready to produce 1000pcs (first batch) for sale ,
You don’t have to worry about the minimum order quantity,I plan to produce this flashlight for the hunting market for a long time.
The weight looks very nice here. But the head diameter concerns me.
One thing I have learned about (white, rifle mounted) “hunting” lights is that I can mount several “stock” (or host modified) lights to give me what I need for the hunt.
For pig hunting in most of my world (several ranches mostly in Texas), most kills are made within 50-150 yards and I need decent flood/spill to track and lead the shots for pig #2 and pig #3 (if I’m lucky) Run times aren’t as much of an issue— as other lights (and night vision) are used to get to a field and find the pigs in range- then the WHITE light on the gun comes on and the action begins and ends within minutes. So my Sofirn C8F (old 18650) direct drive lights ROCK for anything within 225 yards or so.
For coyote hunting, sniper style- I’m guessing something like this light will be a LONG thrower and work great for that. But for most critters Funtastic is listing, I’d elect for a smaller over-all light where heat isn’t an issue even if you have to run it for more than a minute or two (as it’s not in the hand). I ALSO feel the Sofirn C8G is going to make a nice longer-range, throw light on my rifle this winter- for coyotes (as Kansas JUST passed a NEW law, finally allowing lights for coyote hunts at night Usually we hunt them with full moons on snow where a good scope easily allows longer shots, but now a light like THIS one might be in order for the 300 yd plus shots.
I wonder when someone will start using a FET switch (like Lexel’s- that I use ALWAYS) as standard equipment? The current loss on ALL pressure switches WAS my problem up ’till the last few years. Problem solved after finding Lexel here- how I ended up on BLF actually!
I stock quite a range a lights for everything but deer at 400+ meters, this is where Maxtoch beats everything I have, that I can mount, and is why I’m needing something much longer range than the C8 diameter.
I sell the C8+ and L21A with the Osram CSLNM1.TG but the L21A is too heavy and bulky to be mounted.
If you click on my website in my sig you can see that I have everything covered except long range. I get 350-400m of usable lighting out of the Osram C8+ but it’s not enough for what hunters are demanding
One of my customers said for deer 600+ meters is what’s needed and the L21A gets that but can’t be mounted.
This new design would be popular for New Zealand and I’ll be ordering approx 100pcs once they’re ready.
Yes, but my hunts are (always) over in a few shots- so 30 seconds is plenty of time. I LIKE that the C8G driver does hold its highest ramp point in it’s memory too (thought it WAS turbo?). I don’t like that one of my three C8G’s “rings” though. If they sell a host for it (like the C8F), I’d probably by a Lexel driver I can select a single mode on.
What was cool about my old C8F hosts (18650s) is that they went right into 1” scope ring mounts, and one high drain battery could run the three LEDs direct driven on some 18g leads- so no driver needed. I built FIVE of those the last 2 1/2 years and run 25Rs or 20S’s in them. The C8G “concept” is still experimental… I need to built the FET tail switch for the pressure switch Lan sent me last month. But my 125 tomato plants (twin vines per plant/now 8-9 ft tall on twine) is kicking off 200+ lbs a week— so I’ve been busy with that!
So you can hunt deer at night? - cool!!! We go to jail if we do that
My 260ai caliber custom rifle can make an ethical kill at 600 yards on a still deer… on a still day… off a still (and solid) rest But now the Creedmore can also do that with better factory ammo as of late— so I get you have these hunters needing super range.
My use for your light here would be on a coyote across a 1/2 mile long field. It would be on a high power rifle since the typical AR-15 platform doesn’t work at that range (it can’t deliver the required ft/lbs. needed at the deer). It would be mounted to the bottom of the forestock (never the barrel). But as coyotes are plenty fun to pop at 300 yards (and that and pigs are all I can hunt at night), I’d probably BUY this light- but not use it for hunting.
I’d LOVE to live and hunt in your great country! But I am cheap re. paying for guides when I can hang out on public land for long enough and “kill my own” thank you ;). The “pros and cons” of living on ranches 1/2 my life
