Not sure if emails were sent, just looked and didn’t see but I may have missed. Would still like to purchase and had signed up, but was wondering if this was still on hold for now ? My condolences to family and friends.
Manker talks about “HI CRI led” in the specification for the E14 flashlight.
And they write that the flashlight will have 4000lm.
I compare to Emisar. And I see that hi-cri flashlight modifications have significantly less lumens than non-hi-cri flashlight.
This is as it should be, because hi-cri led have a lower lm / w efficiency.
Could Manker be wrong about his specs?
And if the E14 actually produces 4000lm, then how much does it consume from the battery (considering that it does not have the most efficient LEDs)?
This is like textbook what most manufacturers do. They advertise the highest config for specs and may or may not disclose any other versions.
The 90 CRI will be a big hit in output 1) because it’s lower CCT and 2) because it’s higher CRI so expect something like a 20-25% drop for the high CRI.
Thanks for the update M4D M4X! Looking forward to this, now the dilemma begins, what color for the MC13…… white is always good, but I have an Acebeam L17 already, so red or green? Blue would be cool on strobe, you could make bad drivers think a cop is nearby when you walk your dog… ugh its like watching your mother-in-law drive off a cliff in your brand new car…
I just sent the emails with the links and codes for the Manker BLF Combo
(and a bit of explanation)
-> LET US KNOW WHEN YOU PULL THE TRIGGER! :D
please post which options you hae choosen
if you do not receive the email within an hour: - check your spam and other folders! (some mailapps sort in a weird way...)
- search for the senders name: martin.rathmanner@gmail.com
€dit:
mails that came back unable to be delivered: Cmcrap@mailbox.com
