A 3x 21700 batteries tube is going to be a tiny bit wider in diameter than 4x 18650.
Hello Simon, it’s from Page 101 (Mon, 08/31/2020) :
Do you have a change of plan/schedule , coz it’s still not available at your AliExpress store ?
Not that I’ll buy it right away right now but I wanna check the specs etc …
My order is still somewhere on the way (it seems like it has entered my country , that’s a good news) , my wallet will hate me if I buy more flashlight now but it won’t know if I only checking and drooling :laughing: :heart_eyes:
Hello Simon,
Will the KW CSLNM1.TG 6N-ebxD46-15 6000-6500K work fine if driven with your SST40 12group driver ? or should I better stick with the 7135*8 driver instead?thank you
i recommend sst40 12groups driver
Simon Mao: Di_Joker: Simon Mao:What about this one S21B (S11 21700 version)
When roughly expected to be available?
tomorrow
i add a link here
S21B
m47mu74nt:Hello Simon,
Thank you, I’ll order these right away
i add a link here “S21B”:15.27€ 25% OFF|Convoy S21B mit SST40 SFT40 XHP 50,2, kupfer DTP/ ar beschichtete, Temperatur schutz, 21700 taschenlampe, taschenlampe licht|Taschenlampen| - AliExpress
This will be great with KW CULPM1.TG. We need only 4040 gaskets.
Do you plan OP reflector for S21B?
Simon Mao:i add a link here S21B
4040 copper MCPCB is in stock now ,
4040 gasket will be availabe at next week
you can note “OP reflector” in the remarks of your order
I am looking for a work light with decent color rendering, do you plan to sell any high CRI, COB LED based, portable lantern someday ?
New models
Black convoy S21B with luminus sst40 ,copper DTP board and ar-coated inside, Temperature protection management, up to 2300lm
https://www.aliexpress.com/item/1005001400230898.html?spm=2114.12010612.8148356.6.6e1d500bint4VT
Gray Convoy S2+ with samsung LH351D ,Ra>90,DTP copper board ,ar-coated glass lens
https://www.aliexpress.com/item/1005001388842348.html?spm=2114.12010615.8148356.4.312d32f8mZ8s2U
CREE has many types of COB LEDs, I think it is not difficult to design this, it does not even need a reflector.
New models
15.27€ 25% OFF|Convoy S21B mit SST40 SFT40 XHP 50,2, kupfer DTP/ ar beschichtete, Temperatur schutz, 21700 taschenlampe, taschenlampe licht|Taschenlampen| - AliExpressGray Convoy S2+ with samsung LH351D ,Ra>90,DTP copper board ,ar-coated glass lens
13.55€ 25% OFF|Convoy S2 + mit LH351D ,Ra 90, hohe CRI, DTP kupfer bord, ar beschichtete glas objektiv, 18650 taschenlampe, Taschenlampe|Taschenlampen| - AliExpress
Oh,thank you ,i’m adding more items.
C8 KW CSLNM1.TG
C8+ KW CSLNM1.TG
S21A black
4040 20mm 16mm copper MCPCB.
Next week ,i will add links of other osram LED flashlights.
i got driver for KR CSLNM1.23 and 8A driver for KW CULPM1.TG
My wallet....
Annoying but i can't help my self, S21B in grey color, will it be available also? I have only grey Convoys, wouldn't change now to black S21B.
Eagerly waiting for the 4040 gaskets and the 22mm 8A driver to put it together with a CULPM1.TG in a L21a
Same here, that’s what I’m waiting for. I’m also getting a few of the Osram red driver.
Currently using the 8*7135 on the red and it starts out at 230 lumens, drops to 60% within 15 minutes and runs for a further 60min. Since the forward voltage is 2.5v it should run much better with this new driver.
My wallet….
Annoying but i can’t help my self, S21B in grey color, will it be available also? I have only grey Convoys, wouldn’t change now to black S21B.
first batch only black ,sorry
i have samples ,i will assemble one L21A with 8A driver and CULPM1.TG at next week ,and test the data
Yokiamy:Eagerly waiting for the 4040 gaskets and the 22mm 8A driver to put it together with a CULPM1.TG in a L21a
Finally black S21A! I’ve waited a long time for this. Can you measure the inner diameter of the battery tube? I am also interested in the thickness of the walls.
But what about the XHP50.2 emitter version?
Simon doesn't like yellow corona crap which is not present with SST40 and i totally agree with him.
