Me too, I wanna buy this S21B. imo S21B is the new S2+ , this new style is so excitin. S21B is so cool :nerd_face:
S21B and S11 are the coolest Convoys.
Anyway , I’m still waiting for my Convoys to arrive so I’m kinda calming down.
That’s true. I only don’t like XHP50.2 and 70.2 but i like XHP50 and 70 cause they don’t have yellow goo around emitter. In fact i have XHP70 4500K 90CRI installed in M21C. Just beautifull.
It means? There is no information in the descriptions. I am asking because I remember that the first batch of S21A had too narrow tubes and did not fit all 21700 cells.
Please add throw distance meters / cd info for the lights in your store, else it’s impossible to judge what to buy. Good choice to add usb charging for the new lights.
I think I’ll wait for the new version of M3 with USB-C charging and Ramping UI . Then I’ll make a decision to buy S21B or the new M3. or both of them ?
I hope Convoy will make Anduril an option for the new and updated flashlights. Also usb-c charger for as many as possible. Most will then probably chose Anduril.
The maximum output for the LH351D version probably will be a bit less than the Wukkos FC11 (FET driver), rated as 1300lm, but not very different. SST40 gets about 1600lm. Let’s say the LH351D output should be about 75% of the SST40 version output.
Edit: precise lumen measurements would require a well calibrated integrating sphere.
i have few 3V XHP50.2 LED in stock ,
I can also install XHP50.2 as you require.
It’s just that I personally don’t like the uneven light spot of XHP50.2.
