The original weight of the L21A is 366g (without batteries). After being lightened, the weight is within 210g (without batteries), and the appearance has become much simpler.
Thanks Simon
That’s much better at 210g, I was expecting more than that. I’d certainly be happy with that for the Osram range
What’s the MOQ to get that made? I’ll send through an email tomorrow since it’s 3:30am here, I better get to sleep. I’ve been out for the last 2 hours taking photos of the M2 with SST40, Z1, C8+ for my website.
I’m ready to produce 1000pcs (first batch) for sale ,
You don’t have to worry about the minimum order quantity,I plan to produce this flashlight for the hunting market for a long time.
Awesome, that’s wonderful.
Reading the first sentence of 1000pcs, I was thinking “well, I can’t afford that!….oh well” haha
I’ll certainly be ordering a good amount when they’re ready.
Thank you :+1:
The weight looks very nice here. But the head diameter concerns me.
One thing I have learned about (white, rifle mounted) “hunting” lights is that I can mount several “stock” (or host modified) lights to give me what I need for the hunt.
For pig hunting in most of my world (several ranches mostly in Texas), most kills are made within 50-150 yards and I need decent flood/spill to track and lead the shots for pig #2 and pig #3 (if I’m lucky) Run times aren’t as much of an issue— as other lights (and night vision) are used to get to a field and find the pigs in range- then the WHITE light on the gun comes on and the action begins and ends within minutes. So my Sofirn C8F (old 18650) direct drive lights ROCK for anything within 225 yards or so.
For coyote hunting, sniper style- I’m guessing something like this light will be a LONG thrower and work great for that. But for most critters Funtastic is listing, I’d elect for a smaller over-all light where heat isn’t an issue even if you have to run it for more than a minute or two (as it’s not in the hand). I ALSO feel the Sofirn C8G is going to make a nice longer-range, throw light on my rifle this winter- for coyotes (as Kansas JUST passed a NEW law, finally allowing lights for coyote hunts at night Usually we hunt them with full moons on snow where a good scope easily allows longer shots, but now a light like THIS one might be in order for the 300 yd plus shots.
I wonder when someone will start using a FET switch (like Lexel’s- that I use ALWAYS) as standard equipment? The current loss on ALL pressure switches WAS my problem up ’till the last few years. Problem solved after finding Lexel here- how I ended up on BLF actually!
Hi Zappaman,
Thanks for your input.
I stock quite a range a lights for everything but deer at 400+ meters, this is where Maxtoch beats everything I have, that I can mount, and is why I’m needing something much longer range than the C8 diameter.
I sell the C8+ and L21A with the Osram CSLNM1.TG but the L21A is too heavy and bulky to be mounted.
If you click on my website in my sig you can see that I have everything covered except long range. I get 350-400m of usable lighting out of the Osram C8+ but it’s not enough for what hunters are demanding
One of my customers said for deer 600+ meters is what’s needed and the L21A gets that but can’t be mounted.
This new design would be popular for New Zealand and I’ll be ordering approx 100pcs once they’re ready.
Don’t get it with its 30 second timer on Turbo unless you are happy to continuously be double clicking.
Yes, but my hunts are (always) over in a few shots- so 30 seconds is plenty of time. I LIKE that the C8G driver does hold its highest ramp point in it’s memory too (thought it WAS turbo?). I don’t like that one of my three C8G’s “rings” though. If they sell a host for it (like the C8F), I’d probably by a Lexel driver I can select a single mode on.
What was cool about my old C8F hosts (18650s) is that they went right into 1” scope ring mounts, and one high drain battery could run the three LEDs direct driven on some 18g leads- so no driver needed. I built FIVE of those the last 2 1/2 years and run 25Rs or 20S’s in them. The C8G “concept” is still experimental… I need to built the FET tail switch for the pressure switch Lan sent me last month. But my 125 tomato plants (twin vines per plant/now 8-9 ft tall on twine) is kicking off 200+ lbs a week— so I’ve been busy with that!
So you can hunt deer at night? - cool!!! We go to jail if we do that
My 260ai caliber custom rifle can make an ethical kill at 600 yards on a still deer… on a still day… off a still (and solid) rest But now the Creedmore can also do that with better factory ammo as of late— so I get you have these hunters needing super range.
My use for your light here would be on a coyote across a 1/2 mile long field. It would be on a high power rifle since the typical AR-15 platform doesn’t work at that range (it can’t deliver the required ft/lbs. needed at the deer). It would be mounted to the bottom of the forestock (never the barrel). But as coyotes are plenty fun to pop at 300 yards (and that and pigs are all I can hunt at night), I’d probably BUY this light- but not use it for hunting.
I’d LOVE to live and hunt in your great country! But I am cheap re. paying for guides when I can hang out on public land for long enough and “kill my own” thank you ;). The “pros and cons” of living on ranches 1/2 my life
My question is why hunt deer at those ranges day or night. Around here they practically knock on your door.
Hey, they do that…
Probably rut season. You been messing with my woman. Either come out or I’m coming in.
Or he could be a Jehovie…
For clarification they’re going to be used for searching as well. I’ll have a quick release mount installed on the rifle
It’s better to have the extra distance so it’s brighter at a closer range
At the moment I have a mount for the Astrolux FT03 but it’s quite bulky
In West Texas I once saw a man shoot a deer at 1200 yards with a 7mm Weatherby Mag. That guy never left the ranch his whole life
I’ve shoot a handful out over 600 yards or so. Out west, average shots start about 150 yards and 350 is considered a long shot. But with a very good scope on enough rifle (using hand loads we develop JUST for that rifle), getting out past 500 is repeatable given no wind. Some of us can also dail windage (or hold for wind with practice) and if it’s steady and pretty slow still, we can hit a deer at 500 pretty regular.
But never shot one on my front doorstep yet
A lot less dragging when shot from the front porch Shots around here are under 100 yards unless you set up on some farm fields and then maybe 150 yards. Most hunt from tree stands so it could be shorter even. Although most use more modern rounds, not too long ago 30-30s were still common.Those long range shots out west amaze me. A guy I used to know went out west, I forget the state, shot a elk across a canyon with a 264 Win Mag. He used to practice on chucks around here at some crazy distances. My hunting days are over but if I needed meat it would be out the window with a 22lr to the head.
Couldn’t agree more, I love headshots- NO meat loss! Then you just need a sharp knife
…oh and ya, uh… maybe an SP40 or my super old floppy-ass C8 headlamp— to see where you need to after the kill.
Is the surface of the previous design too smooth? How about changing to the following?
That’s much better then a smooth body. I prefer knurling
C8+ knurling is my favorite.
