Astrolux EC03 - 6700 Lumens - Test The Temperature - Best Value 2020
8 posts / 0 new
vietnamreviews
Astrolux EC03 is an amazing flashlight. With the use of 3 LEDs XHP 50.2 very impressive brightness up to 6700 lumens. The lamp’s heat dissipation ability is also very impressive. What do you like the Astrolux EC03 the most. Please leave a comment
richbuff
Last seen: 1 hour 18 min ago
Thank you for your thermal review. I ordered one of these as soon as it was announced. I bought two more, for a total of three, because the price is very low for the quality and also because of the beam profile and beam performance per size and and weight. Astrolux came up with a winning combination with 3 x 50.2 and single 21700 and smooth reflectors in a medium size diameter head and stainless bezel and high quality and low cost. Ample power for size from 3x 50.2, and also ample throw from reflector wells that are not too small and not too shallow and not too overlapped. Also, the throw and lumen  specs are not overstated. To my experienced eyes, compared with more than a few other small-medium flashlights, the throw and lumen specs are understated.  If I were the King of the flashlight world, I would decree that everyone should have an EC03.
Rev 22:15
ArturoSC1
Last seen: 1 week 3 days ago
How did you config the temperature? Anduril does not usualy reach that temperature
vietnamreviews
Off — 3 fast click —>Battery check — 2 fast click —> sunset — 2 fast click —> beacon — 2 fast click —> tempcheck — 4 fast click —> thermal cfg
Cfg: 1.Current temperature: Click N time for n deg c 2. temperature limit: click N time for 30 c + N
vietnamreviews
richbuff wrote:
Thank you for your thermal review. I ordered one of these as soon as it was announced. I bought two more, for a total of three, because the price is very low for the quality and also because of the beam profile and beam performance per size and and weight. Astrolux came up with a winning combination with 3 × 50.2 and single 21700 and smooth reflectors in a medium size diameter head and stainless bezel and high quality and low cost. Ample power for size from 3× 50.2, and also ample throw from reflector wells that are not too small and not too shallow and not too overlapped. Also, the throw and lumen  specs are not overstated. To my experienced eyes, compared with more than a few other small-medium flashlights, the throw and lumen specs are understated.  If I were the King of the flashlight world, I would decree that everyone should have an EC03.
I also think it’s great
patmurris
patmurris's picture
Last seen: 2 weeks 2 days ago
Amazing light indeed.
Did a quick spring bypass with copper braid and i gained a couple thousand more lumens – just in case… Evil
vietnamreviews
Will probably be 10000 lumens like
Lumintop fw21 pro 3x xhp50.2
aeroden
Last seen: 7 months 4 weeks ago
patmurris wrote:
Amazing light indeed. Did a quick spring bypass with copper braid and i gained a couple thousand more lumens – just in case… Evil
Do you have any pictures to share please? When I press on the spring in EC03 it feels like it clicks and it looks like there is PCB? behind the spring?
