KD specs suggest 2S based on voltage. Freeme translate for us
Yes, I missed that.
Well, that may be a first. Buck driver of over 20 amps.
I have the JKK03 and the driver is quite good in maintaining output. Just took it out and may look further in it.
Edit (@10:00 PM):
Tested the JKK03 and dropped from 941 to 805 lux in 6 minutes. ~15% difference and head at 57.6ºC. Very good regulation and if thermal step-down would have to be higher than 60º
JKK90 SBT90.2 with single 5000mAh 26650
Size: 72mm x 34mm x 165mm
Weight: 580g
Group 1: Lo > Med > High > Turbo (double click), triple click for strobe-SOS
Group 2: Ramping, double click for strobe-SOS
Triple clicks during OFF state to switch between Groups.
Mode:
Level 1: 350lm 9hrs
Level 2: 900lm 2.5hrs
Level 3: 2800lm 45mins
Level 4: 6800lm 249Kcd; temperature control, stepdpwn 1.5-2.5mins (summer weather)
JKK90 SST40 WCS F50 with single 5000mAh 26650
Mode:
Level 1: 200lm 12hrs
Level 2: 600lm 3.5hrs
Level 3: 1300lm 1hr
Level 4: 2800lm 202Kcd; temperature control, stepdpwn 5-10mins (summer weather)
JKK90 XHP70.2 version with dual 26650.
New trend for budget lights?
MEEJAS D201
Weight: 580g
I’m trying to understand this; the JKK90 w/ SBT90.2 can be found in single cell format?
And the shown images on KD would be for the XHP70.2 2S models?
So where do I buy the single-celled light?
The worse part of those digital displays is when they show the "fake" lumens for levels. But the voltage and temp shown is pretty awesome. Showing moon, low, med, hi, turbo would be better. For ramping, a percentage would be cool.
Funny they are getting more popular on budget lights. Could be problems with water and reliability issues for main stream manufacturers.
The worse part of those digital displays is when they show the “fake” lumens for levels. But the voltage and temp shown is pretty awesome. Showing moon, low, med, hi, turbo would be better. For ramping, a percentage would be cool.
Most likely they’ll just all get stuck with unusably bad UIs and we can’t mod them without losing the display.
New Jaxman Z3 “inspection flashlight”
Battery: 26650
Lens: Glass lens*2
Flux: about 500 lm
Switch: rotary tailcap
Link in the pic.
Fixed flood aspheric?
Any more info about it?
It's an interesting light. Something like that would be ideal for a guy I know that has a biz inspecting and rating classic cars. He's got a few inspectors. Might want at least a lo-hi though. Doing close-up work, nice to set the output lower.
Little too pricey though. For that cost, we would need much better details. The spot size in the diagram doesn't seem to match that pic of looking down at a car - 225 cm diameter at 5 meters I would think would be a much larger spot at distance.
Same light, little cheaper here: AilExpress - EDC headlamp
Don't know if any good at this point. For that price, hard to believe it's quality regulated driver, quality anodizing, good threads, decent LED, etc. Other option is for a mod host, then it's a matter of easy access, and that weird charger setup may be a problem.
Don’t know if any good at this point. For that price, hard to believe it’s quality regulated driver, quality anodizing, good threads, decent LED, etc. Other option is for a mod host, then it’s a matter of easy access, and that weird charger setup may be a problem.
You’re probably right! Not the best option as a pseudo Olight-wannabe!
I guess it will be a bit messy to mod one of these (with my skills I mean). I’ll pass on it then
Thanks for your feedback Tom E, always helpful!! :+1:
bezels look pressed in as well. bummer
Page Not Found - Aliexpress.com
Good or bad?
When you find that perfect, budget mod-ready headlamp let me know! I’m also in the market…
I just modded a Amutorch AL1 headlamp last night - 20 mm FET+1 driver, sliced 351D 4000K, Anduril2, 22 AWG wires.
Was a pretty easy mod. Bezel unthreaded easy, poked out the driver easily, decent access to the MCPCB. Kept the stock MCPCB - was about 20 mm diag but only 1.0 mm thick.
It's nothing fancy though - SMO reflector, no switch LED's. It says the tube is titanium but feels like SS because of it's weight. Little too heavy for a headlamp to me.
I wanted decent tint, decent throw, to use more like an EDC rather than headlamp.
Hum, headlamps sometimes are not easily modded due to the drivers/switches/chargers, but they are out there.
Getting one without charging capability would be my first point in case I wanted to mod one.
I have an Acebeam H20 in the drawer ready to be modded, once I order the driver. I will implement a driver with Anduril because I can make it fit in the flashlight. Otherwise, I’d just leave it the way it is
