Water Cooled Flashlight Modding a MT35 PLUS RE-MODDED
83 posts / 0 new
Yokiamy
Yokiamy's picture
Last seen: 1 hour 25 min ago
Nice !
pinkpanda3310
pinkpanda3310's picture
Last seen: 3 hours 43 min ago
Cool!! (pun…?). Awesome project CNCman. Interested to see how much difference your mod has made (with regard to thermal abilities of course).
CNCman
CNCman's picture
Last seen: 2 hours 40 min ago
Still getting things ready for some testing on the light and making a Lumen tube to check it also.
I was not sure how the driver would handle long run times so we decided to add a copper heat sink to the rear of the driver with Artic MX-4. There is 3mil tape in the area of a possible short.
The light was coming on when the battery tube touched the spring and not when seated. So we turned the outside diameter and taped it.
CNCman
CNCman's picture
Finished compact battery holder.
Just under 8 amps @ 12 volts. Guessing around 8500K lumens, not able to get accurate readings yet.
8 inch lumen tube is not calibrated yet, guessing it’s reading high 2K.
Re-plumbing with good tubing.
Beam shots don’t really show how nice it shines.
low ramp start.
25010 lux at 6.46 meters is 1,043,707 CD and 2043 meters throw, approx 8500 lumens.
This light just blew a mcpcb 1 day after I changed a burnt XHP70.2. I will fix it again with another modded mcpcb.
Texas Ace has a Luminus 90.2 kit ordered I will probably put in, but that will require more invasive work, so I may put that kit in another big light. Big Smile
I know this light looks strange, but it is an experiment in heat control. If were possible to find a very small pump, it would be possible to incorporate the cooling into the head ( no exterior tubing ), and improve its appearance. Wink
originally MATEMINCO MT35 PLUS, XHP35 HI, 4 × 18650 batteries
I want to Thank the many BLF members who helped me during this mod. Beer
Tally-ho
Tally-ho's picture
Last seen: 2 weeks 1 day ago
The water-block is genius, so how about taking advantage of the length of the battery tube for cooling the water temperature ?
Something like a battery tube with milled fins on the whole length and the water pipe going through the fins. Sorry for the 4 years old kid drawing Facepalm
CNCman
CNCman's picture
I never thought of going around the battery tube and adding a handle, Good Idea Thumbs Up
Definitely looks better too Cool Yes, that is the way to do it, wish I had thought of that in the beginning Thumbs Up
grin
Last seen: 1 month 1 week ago
I couldnt think of a good way to do build water blocks but your builds have given me some good ideas to work with.
kennybobby
kennybobby's picture
Last seen: 2 hours 6 min ago
The_Fat_Controller wrote:
Well, when they show a wavien collar…
You can see there he has picked a lens with a monstrous 100mm+ FL to make the effect as dramatic as possible.
Thank you for post #44 that very informative vide and your beamshot, quite impressive.
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
CNCman
CNCman's picture
This one is much cheaper and easier to make.
grin
They are both well done.
I am thinking the copper tube with a web soldered between them so it is similar cross section to an I beam would be rigid enough to take the place of a spider.
CNCman
CNCman's picture
. Mine are overkill in size, you can go much smaller because the water will take the heat away, just make sure the pump is on before the led. Wink
I’m searching for a front mirror coating also, found this one for glass, it might work on aluminum. Just need to learn the process, not buy the kit, its expensive.
https://angelgilding.com/pump-spray-silver-kit.html?redirect_log_mongo_i...
https://www.youtube.com/watch?v=MoK4s-MFo4I
MascaratumB
MascaratumB's picture
Last seen: 18 min 10 sec ago
This is a great build Shocked
Well done CNCman Thumbs Up
grin
Sorry wrong thread
CNCman
CNCman's picture
Thanks for the comments BLF’rs Big Smile
Sorry it took so long to finish.
Sirstinky
Last seen: 37 min 58 sec ago
Awesome project. I wish I had a lathe and mill to do all that you do. 8500lm is nothing to scoff at for sure.
lumenzilla
lumenzilla's picture
Last seen: 8 hours 34 min ago
If the water pipe is transparent, I’d like to see it with fluorescence and UV light to “ignite” it Smile
CNCman
CNCman's picture
After burning a few mcpcbs and leds it was time to correct some misjudgments in function and appearance.
The 20mm mcpcb was upgraded to a 32mm and the 20mm pocket was filled with a copper coupon and soldered in place. Then re-surfaced, drilled and tapped for mounting screws.
A new centering ring had to be machined and fitted in place with a dremel tool. Very difficult to get it right, took 3 attempts.
Relocated the aluminum cooling coil and resized it with the correct amount of cooling capacity, previously overkill.
Machined a battery tube adapter to combine two short tubes.
Rewired everything with shorter wires.
Didi-Key XHP 70.2 5700K dedomed led.
The centering ring was very challenging to machine.
The wires had to be held down while soldered.
Side view showing inlet and exhaust tubes.
Ready for installation.
FINISED Big Smile
Left XHP 70.2 ….. Right Luminus SBT 90.2.
The led was from Digi-Key at XHP 70.2 5700K before dedoming.
The driver is 12v 8amp from Lexel with 5v power supply for pump.
Runs cool and only gets warm in warm weather.
The dedomed Digi-Key XHP 70.2 5700K performed much better than the 6500K dedomed Mtn. Electronics led.
12V 8Amps on turbo
1.372,969cd
9,200lm
2,343m throw
Specs for Luminus SBT 90.2 not water cooled.
3V 22 amps on turbo
1,829,513cd
5800 lumens
2700 meter throw
https://budgetlightforum.com/node/76083
It is hard to beat the XHP 70.2 when driven hard. Wink
A lot has been promoted about the SBT 90.2, but the proof is in the beam shots.
When standing behind the two lights, I give the 70.2 my vote. Wink
Enderman
Enderman's picture
Last seen: 14 hours 53 min ago
Very nice job on the MCPCB modifications Smile
Great performance results.
CNCman
CNCman's picture
Thanks Enderman. Cool
I have watched several of your builds and they inspired me to try new things. Love
Enderman
Enderman's picture
Yay I’m glad I could inspire people with my builds Big Smile
I wish I had my own lathe and mill to do stuff like you tho haha
Skylight
Skylight's picture
Last seen: 8 hours 51 min ago
The water cooling in black now looks like it really belongs there. Nice to see how you improved the copper heat sink, the MCPCB and the whole water cooling system. Very neat and professional. Thumbs Up
Really useful comparison of the dedomed XHP70.2 and the SBT90.
CNCman
CNCman's picture
Thanks Skylight Big Smile
It was put on hold for other projects for too long waiting for a SBT90.2 that was never installed. DB Custom suggested that I leave it as is and build another light, he was correct and that is what I did. I really liked the XHP70.2 with more lumens than the SBT90.2 with more throw. Wink
