Lookin forward to your report with the switch. I’m not a huge fan of the travel, but at the same time it is kind of nice to not worry about it accidentally triggering.
We are writing to inform you that we have refunded 473.0100 SEK for order 83896690. Your order has resulted in a refund for refund for quality problem . Please allow 48 hours for your refund to be processed back to your original payment method. If it is for credit card payment, it may take up to 7-14 days to show in your account
Mine arrived today (thanks for the GAW, MascaratumB!!)
I’ve only played with it for like 1 minute but it seems to be in good order so far. Bright, connection is good after I tightened it (it did flicker at first), beam pattern is fine in mine (no donut hole, LH351D version). The noisy button is kinda annoying but nothing I can’t live with (or honestly I can probably find that with a new e-switch or something). I’ll give it a good run through tonight when it gets dark.
I hope they could correct the “beam artifacts” issues for the Meote FM1 with XPL-Hi and SST20 LEDs (the LH351D is acceptable beam, other than lower brightness than expected). The XPL-Hi and SST20 have also lower brightness than expected and with noticeable beam artifacts. If they change the optic in the updated versions, I expect that they can ship out the replaced good optic for those who purchased the early batch FM1 with the poor beam artifacts on SST20 and XPL-Hi LED versions.
This issue seems a bit common for flashlights that don’t use springs on both ends of the battery tube (head & tail). The Meote uses a button on the positive side, thus a bump may disconnect (a spring will usually not have this issue) — however I think having a button may have some advantages (lower resistance for current to pass?)
