OSRAM CSLNM1.TG & CULNM1.TG 1mm², CSLPM1.TG & CULPM1.TG 2mm²
1420 posts / 0 new
Coyote2710
Scallywag wrote:
Coyote2710 wrote:
Sunnysunsun wrote:
Coyote2710 wrote:
hello, best driver for osram 1mm red (CSLNM1.23) around 1.5-2A using single 18650? continuous use on C8+.
5 or 6*7135
thanks, but what do you think about the heat with the low Vf?
I’d use a buck driver.
which one do you recommend?
Barkuti
Barkuti's picture
Last seen: 1 week 4 days ago
I gave you an answer here.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
ZILZAL
Any new experiments with the CULPM1.TG ?
ZILZAL
I found this on youtube, ( i dont understand a word from it)
Funtastic
Funtastic's picture
Last seen: 33 min 10 sec ago
Hmmm, he’s using a fet driver. That’ll be great if it can handle it
Piercing The Darkness YouTube channel – https://www.youtube.com/c/PiercingTheDarkness
ZILZAL
Simon (convoy store) has listed this new beauty C8+ with osram KW CSLNM1.TG 6500K https://www.aliexpress.com/item/1005001400455356.html
Max range: 748 meters (140kcd)
Funtastic
Funtastic's picture
I got 915m range at 4.2A, 700 lumens, and Convoy are using the 5A driver so it’ll do better.
I wonder why the rating is so low
luminarium iaculator
luminarium iaculator's picture
Last seen: 2 days 23 hours ago
Everyone should mention candela rating and not meters… ANSI standard? Well it kinda sucks… Mine 280 kcd light for me has usable 500-600 meters beam distance(depends on the night)… This is individual stuff. Cause there are areas with ultra dark nights where ansi measurements can actually pass. But it mostly won’t pass. So I don’t take only the beam distance as a relevant data… Candela rating tells much more about light so if candela rating is true and “right” by my personal experience I can estimate throw by my night conditions…, and if 140 kcd is true that is around 200-250m of usable light in mine area…
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 2 weeks 1 day ago
They convert perfectly back and forth. Neither measurement tells you any more or less than the other. Just take 2/3 or 1/2 the FL1 throw based on how much intensity you want at a given range and there’s your real-world throw.
In fact candela ratings can be deceiving since it requires exponentially more to increase throw, whereas doubling FL1 throw from 100m to 200m will have the visual and practical difference you would expect.
AgentWhiteBread
I saw on the first comment they’re discontinuing the CULNM due to lack of sales. Does anyone even sell a light with the CULNM LED? Sadly my hands shake too much to do any sort of soldering or I would attempt it myself.
Barkuti
Barkuti's picture
Everyone should mention candela rating and not meters... ANSI standard? Well it kinda sucks... … Candela rating tells much more about light so if candela rating is true and "right" by my personal experience I can estimate throw by my night conditions...
BurningPlayd0h wrote:
In fact candela ratings can be deceiving since it requires exponentially more to increase throw, …
Well I hear you both. I sort of lean to luminarium iaculator's perspective, as I also prefer a luminous intensity rating because effective throw depends on the ambient light intensity, and also on our expected over the target light intensity.
However I also understand throw is directly proportional to the square root of luminous intensity, which means there is no direct linear relationship between intensity (candela) and throw (meters).
I do not think that is deceiving, as I understand it. The same applies for anyone knowledgeable in the matter with a minimum of expertise and/or mental agility. This is key.
I could also seriously mess with the way luminous intensity is defined, but overall I guess the actual problems and reasons are often rooted in common people's stupidity and caused by smart people pledging to their uneducated wishes.
Agro
Agro's picture
Last seen: 55 min 42 sec ago
BTW, has anyone tested Boost HX already? How does the performance scale compared to CSLPM1.TG?
JaredM
JaredM's picture
Last seen: 7 months 2 weeks ago
I’m anxiously waiting for this, too. At the rate these are becoming available in good bins, budget LEP will be here
https://fundrazr.com/osturaband
No affiliation, just a fan.
Yokiamy
Yokiamy's picture
Last seen: 3 hours 44 min ago
Simon Mao will put one in a L21A with an 8 A driver soon and share the results!
Eager to know the results, if they are any good i will certainly buy some parts
http://budgetlightforum.com/comment/1692738#comment-1692738
ZILZAL
Simon listed 2 new 4040 DTP copper MCPCBs for osram KW CULPM1.TG, 16mm and 20mm.
16mm: https://www.aliexpress.com/item/1005001416992562.html
20mm: https://www.aliexpress.com/item/1005001417023203.html
ZILZAL
Simon tested the CULPM1.TG on L21A got this result, it looks impressive
Simon Mao wrote:
i test L21A with KW CULPM1.TG and 8A driver today . The illuminance value at 5 meters is 14190LUX, and the range is about 1190 meters.
JaredM
JaredM's picture
That size reflector should see close to 450kcd max with this emitter according to my estimates.. we’ll see what others get. I don’t think the 8A driver actually pushes 8A. If course without an output test done on these yet it’s hard to say how much is here on the table just with drive current. Also, I’m not sure how much time if any he put into optimizing focus. Does anyone else have experience with the 4040 gaskets? Are they as thick as the 3030s?
ZILZAL
Simon Listed Convoy M21A with KW CSLPM1.TG 6A driver
4 & 12 modes // Black & Desert Tan body
https://www.aliexpress.com/item/1005001433292831.html
Nice, waiting for the CULPM1 version
d_t_a
Last seen: 5 days 12 hours ago
What’s the difference between CSLPM1 and CULPM1? Both are 2mm size emitters right?
I wonder if the current batch of M21A now accepts the slightly wider 21700 batteries (eg. Lii-40A and others). The earlier M21A won’t fit the Lii-40A (or Lishen 21700)
Barkuti
Barkuti's picture
d_t_a wrote:
What's the difference between CSLPM1 and CULPM1? Both are 2mm size emitters right? …
Footprint. CSLPM1 is 3030, whereas CULPM1 is 4040.
Scallywag
Scallywag's picture
Last seen: 7 min 49 sec ago
oweban wrote:
from the convoy thread
so, the difference is 3030 footprint for cslpm1 vs 4040 footprint for culpm1
Yokiamy
Yokiamy's picture
Exactly. The idea is that the larger footprint allows higher currents due to better heatsinking.
Osram’s datasheet says 6A, but since when did we use to stick with specs from datasheets?
We run cree LED’S on currents not even mentioned by Cree Wink
Barkuti
Barkuti's picture
Osram's datasheet says 6A, …
All else being equal, I think the effective difference will be rather small.
Yokiamy
Yokiamy's picture
Barkuti wrote:
Osram’s datasheet says 6A, …
I’m curious what the difference will be, since the surface area is 77,77% larger. (16mm instead of 9)
That means it can be abused a bit more (run higher currents) or sustain longer (better thermal dissipation/better performance)
Barkuti
Barkuti's picture
When I say that the effective difference will be rather small, I am speaking about lumens or radiant flux, of course.
The 4040 footprint will handle higher current, but that extra (Vf × I) power will only partially turn into extra lumens or flux.
We'll see.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 11 months 2 weeks ago
I wonder if the rather small amount of more efficiency on CULNM1.TG / CULPM1.TG will be advantageous if used in a multiemitter array, e.g. underneath a quad optic. I hope to seeing some flashlights using CULNM1.TG underneath a Carclo 10621 optic anytime soon. Maybe Hank (KR4/D4v2) or Sofirn (IF25A) can offer something like this. Acebeam is using CSLNM1.TG (White Flat 1) in their TK16/TK18 lights.
contactcr
Last seen: 11 min 6 sec ago
Like this?
LEDs: Osram White Flat 2.1 4040 Boost HX
Driver: MTN-17DDm (w/ Bistro firmware)
Optics: Ledil Angie
Lens: UCLp AR lens
~77kcd
~4470lm @ 3s
5500K CCT
Lux-Perpetua
Yes, very nice work. Thumbs Up Actually, I hope it can also be done with a 10mm lens as LEDiL ANGIE-S is a bit larger.
KawiBoy1428
KawiBoy1428's picture
Last seen: 36 min 35 sec ago
contactcr wrote:
Like this?
Optics: Ledil Angie
Lens: UCLp AR lens
~77kcd
~4470lm @ 3s
5500K CCT
!{width:85%}https://i.imgur.com/59TU8PL.jpg!
Is that a 3535 board?
KB1428 “Live Life WOT
contactcr
Yes 3535. I had a mosX 4040 board I took some Luxeon Vs off of but I kept getting shorts I couldn’t fix.
