I’ll be surprised if the numbers are anywhere near what they are claiming and the price! Can’t wait to see the actual numbers when the light is tested.
I don't understand the above critiques on the throw. Let me explain:
a 100 mm head light easily did 700+ kcd on old dedomed XP-G2's (my BOSS1 as a good example)
triples in the same overall dimensions usually do slightly less than a single
SBT90.2's driven well should easily out perform old dedomed XP-G2's
so 750 kcd real world from a triple SBT90.2 driven well with overall 100 mm head diam should be quite do-able, suspect 800 kcd or so if it were a single SBT90.2
freeme -
is the UI a total unknown at this point?
I would suggest fixing the OP specs: 750 kcd, 1732 meters -- this would match Neal's listing
I had some Emails to Martin (M4DM4X). He told me, that Neal has Anduril on the HK90.
I had also private messages to Toykeeper. She told me, that she never had worked with Haikelite for HK90. Hope I´m allowed to post this here.
So I´m not sure, what UI HK90 has. I hope HK90 has anduril, maybe “only” a ramping UI…
Thanks Tom. I haven’t had anything relevant to add to the forum for a while now. So I turned into
a lurker. Just decided which new light to purchase these days.
freeme posted the Anduril UI and HK user manual at another location: werforums.com/vb/showthread.php?470067-%E2%99%9B-Group-Buy-Haikelite-HK90-3*Luminus-SBT90-2-High-Lumens-3*21700-Flashlight&p=5414548#post5414548
Shame if it's an old Anduril version from 2019. Early 2020 she made significant improvements to the thermal regulation, for one thing. I'm actually modding with using Anduril2 with has other improvements like voltage calibration, but it's still in on-going development.
Would be interested in hearing more from HK on this. According to TK, HK doesn't contact her. The way I understand it, they don't have her approval because they never asked for it - they just don't communicate to her, or me for that matter. I don't know details here - could be other issues...
Hello,
are there some lights shipped yet?
Seems, that they are still not yet in stock.
I´ve not bought here in Groupbuy.
Thanks.
Another question.
Are cells with very high drain and bypassed Springs also maybe cause damages, like in other flashlights with DD Driver.
I know. that Anduril is regulated wide range, but Turbo will be direct drive.
Are someone here who plans to “Dedome” the LEDs ? (Remove the Window of LEDs)?
Thanks.
