There is the Wainlight C8+ with Osram NM1 LED, this is very similar to other C8 flashlights, but produces a more focused (more throwy) beam, but less total light output.
left:Convoy C8+ with XPL-Hi LED
right: Wainlight C8+ with Osram NM1 LED
Osram NM1 LED has a very tiny light emitting portion (the yellow square)
left: Convoy C8+ with XPL-Hi
Osram NM1 lights up a smaller area but more intense (throws farther).
I suspect the FT03-Mini with Osram NM1 will have similar throw (or a bit better) as the Wainlight C8+ with Osram NM1, but with better user interface.
Also the Osram NM1 LED on the Wainlight C8+ only uses up to 2.8 Amps max power, not yet maximizing the Osram's potential. Hopefully the FT03-Mini will better optimize the power (maybe like 4.5 Amps of power applied to the Osram LED), and also have a well-focused reflector.
From the pics of the beamshots, green looks like the best thrower, which makes sense from the NM1 specs and other tests/rating comparisons of the white and green.
I wonder if the sensitivity of the Lux meter being used is also going to influence the measurements. I have no idea how different colors will be interpreted by it.
