Interestingly, the O-ring mod did not increase activation force for my KR4 like it did on all of my FW3s. So I didn’t bother to 3D print a larger gasket to fix the button slop. Though I might try trakcon’s configuration and see if that will make the switch action better for me.
I added an O-ring to trakcon’s configuration. So the order of parts from outside to inside:
Button
Brass nubbin
Rubber boot
O-ring
Switch board
By moving the brass nubbin to the button, the clicky feedback feeling increased. After adding the O-ring, it seemed to stabilize the button and is less wobbly. It’s stable enough where I don’t think I’ll need to add a gasket around the button like I did in the FW3s. The click is less pronounced than the FW3s though.
Not sure how you all managed to put the brass nubbin between the steel button and the silicone boot. The little steel nubbin on the steel button has an OD of 3.5 mm and the brass nubbin has an ID of 3 mm. Or something has changed from early to later models.
Anyway, I tried the spacer ring between tailcap and steel button as described by someone else in this forum for the FW3A. My first try with 0.4 mm thickness was already good enough. Less wobbly, but also slightly easier to activate. Also the button does not scratch against the tailcap anymore. I’ll keep it like this for a while.
Please help - completely off topic and I apologize but can anyone help me with what optic the KR4 comes with stock? 10621 / –22 / –23? I am pretty sure I know its not the –23. i ordered a –21 from Mtn electronics because i thought the KR4 came with a –22, but the –21 kind of looks like whats in my light now? I don’t want to bother Hank with these basic questions… again…
Thank you for the info! I will have to put in the 10621 I got from Mtn and see if there is a difference from what is stock in my KR4. They visually look very similar. Hopefully I didn’t get a 10622 sent to me… I wish there was some marking on the optic to distinguish them. I’m new to this, there probably is some way to tell the difference
You’re welcome! The 10621 and 10622 are similar looking. However, the 10621 has slightly recessed circles (lenses?) directly over the emitters, whereas the 10622 is smooth across the top. See here (not my photo): 10621. I hope that helps.
I just popped it in the KR4 (sst-20 5000k) and… Wow, its awesome! I recently bought that 10621 along with the 10623, 10507 and 10509 to switch my optics up. I was saving the 10621 for my “custom” (from Hank) d4v2 brass with W2’s (my first d4v2 :D) that is in route to me now, due this week, thinking I would put the 10623 in my KR4 and have a “thrower” and a “flood” edc, respectively. But now I’m scratching that and putting together a Mtn electronics order to get another 10621 for the KR4. It almost looks like it gave me 50% more throw. I know its not that much, but it is definitely noticeable over the 10622, much more then I expected! Almost looks like it throws as far as my EC03 (I just got that one in this week too, another great little torch!). No wonder why this hobby is so damn addictive… :innocent: Thanks for the help again.
You’re welcome! I’m glad you like the results. I have 10621’s and 10507’s in most of my quads and triples. It’s made a huge difference in enjoyment of use for me.
Received the soft blue camo today with Fedex but without having asked it ; took 3 days . I have a better feeling with this switch than from my other ti . So now i have e21a’s in 5000,4500 and 5000/3500 .
Funny . I didn’t beleive it too when fedex rang my door ; i had received hank shipping email today, but didn’t bother to check . Can’t satisfy you today : no phone and my camera is in one of my boxes from my moving .
I want to almost completely because i am so curious after reading everything n here from people that know so much about color “temperature” (I don’t know if thats even the right term). but yea, a 2000k mule sounds awesome.
