[Review] Lightstar InfiniStar 700 (1x18650, tail e-switch, Nichia 219D, orange, complete kit)
The Product
Battery Junction reached out to be recently with interest in sending over a few of their products for review, and this is the first of those - the Lightstar InfiniStar 700. This is a compact single 18650 light with a tail e-switch, and a Nichia 219D emitter. This light is available in the orange body color seen here, as well as a less eye-catching grey.
Spoiler
There's a lot to like about this light at the surface, which is why I requested one to try out - the light has a tail e-switch, a high CRI Nichia LED, and a great orange color option available.
My major issues are that the light requires a long press to turn it off, which I don't like, and the LED it uses doesn't seem to exist in a high CRI version. Aside from these quibbles, the light is superbly compact, comes at a very reasonable price, and looks great. I would prefer a different UI with a lower low mode, but otherwise it's a competitive offering.
It is worth noting that the physical design has enough in common with the Folomov 18650S that I suspect they share a manufacturer.
Physical Dimensions
The InfiniStar 700 measures 101 mm long, 25.2 mm at the head, and 22.8 mm along the body. It weighs 48 grams without a cell, and 96 grams with the included one.
For comparison, here's the light next to an unprotected 18650 cell, the Lumintop FW1A, the YLP Unicorn 1.0, and the Convoy S2+. This is notable head to head with the FW1A, one of the shortest single-LED lights on the market with a tail switch.
Build
The light is made of aluminum with a bright orange anodization.
The bezel is smooth and shallow. Behind the bezel, the shallow cooling fins have some notches cut through them along the length of the light to help prevent unwanted rolling.
Most of the body and the tail are covered with a flat-topped diamond knurling to help with grip.
The tail has a silicone boot over the switch, which is recessed to prevent accidental activation. There are holes on one side for the lanyard to attach as well. The raised edges are flat, allowing the light to tail-stand.
The tail-cap is easily removed for cell swaps. The threads here are anodized, which means you can lock the light out to prevent accidental activation by slightly loosening the tail. A small spring serves as the negative contact. You can see that some of the thin anodization has worn on the threads already, so lockout may not be reliable after extended use.
The head can also be removed from the body. The threads here are not anodized, so the cell tube isn't reversible. The positive cell contact is a slightly recessed button.
What's Included
The light comes in a plastic blister pack. Inside, you get:
  • The light itself
  • Pocket clip
  • 18650 with micro-USB charging port
  • USB-A to micro-USB cable
  • Lanyard (with a pin to make threading it onto the light easier)
  • Spare o-rings
Notably there's no manual included, and one really isn't needed - the instructions on the back of the package go over the simple UI with enough detail.
Ergonomics and Retention
This small light is quite comfortable in the hand, and the switch being at the tail makes it easy to locate.
The clip that comes installed only attaches at one point on the light, for head-down carry. It's not a deep-carry clip, but it has a good profile.
The included lanyard can attach to the holes in the tail, and includes a pin to make attachment easier.
Modes and Interface
All functions of the light are controlled by the tail switch, and the UI is simple.
  • From off, click to turn on in the last used mode
  • From on, click to cycle high (700 lumens claimed) to medium (250) and low (35)
  • From on, long press to turn off
Many enthusiasts will long for a lower low mode, lockout, or some other added features - but simple UIs are great for many users, and easy to get used to. My only real complaint is that I believe the actions from on should be swapped, so a single press turns the light on and a long press changes modes.
Light Quality and Beam
This light uses a Nichia 219D in a reflector with a very faint orange peel texture. LightStar claims this emitter is >90 CRI, but at this time Nichia shows only 70 CRI options available. Based on this, I have to wonder if Lightstar is mistaken about the details of the LED used in this light.
That doesn't mean that the LED is a bad one - the image above shows it throws a surprisingly tight beam. Next to the 4500K E21A on the right, you can see that there isn't a whole lot of tint shift in the light, though the hotspot is a bit yellow compared to the spill.
Power and Runtime
The light is powered by a single 18650. With the recessed positive contact, a button-top cell is required.
Testing was done both with the included 2600 mAh cell, and with a higher capacity 3400 mAh Titanium Innovations 18650. On high, there's a drastic step down 1 minute into the test down to about 40%, which matches the medium level of the light. Medium also shows a step down, but at around 3 hours.
In all tests, the output tracks down as cell voltage drops. It's notable that, in addition to running for longer on high, the Titanium Innovations cell shows less of a drop in output towards the end of the run. With the included cell, the runtime on high and medium were 3.8 and 6.6 hours, which are notably lower than the manufacturer's 7 and 10 hour claims.
Charging
The included cell and the Titanium Innovations one used for testing both feature built in micro-USB charging. As with all cells of this type, just plug in a micro-USB cable after removing the cell and it will charge up. A red LED on the cell indicated it's charging and turns green once complete.
This isn't my favorite form of charging as the cell needs to sit loose and exposed to charge and gets quite warm, but it's inexpensive for manufacturers and convenient for users so we see it quite often.
The included cell charges at 0.7A and takes just under 4.5 hours to charge completely, terminating when the charge current drops below 0.1A.
Summary
Pros:
  • Full kit - a light, a battery, and a way to charge it
  • Extremely compact for a tail-switch light
  • Neutral white
  • Great body color options
  • Simple UI
Cons:
  • Doesn't meet runtime claims
  • Questionable CRI claims
  • Long press for off, no mode shortcuts
Notes and Links
This product was provided free of charge from Battery Junction. I was not paid to write this review, and have tried to be as unbiased as possible.
InfiniStar 700 product listing where you can pick one up for yourself.
Titanium Innovations 18650, for a higher capacity cell to use.
Thank you for the review. Nice work.
Thanks! I always love getting a chance to review less common lights or brands.
Thanks, nice to see another brand that offers compact lights. :slight_smile:
Thanks for your review.
I have a question about the tail e-switch, how does it work , compared to Lumintop FW series tail e-switch ?
I mean, Lumintop FW has an extra tube inside to convey the e-switch signal to the driver , I don’t see extra component in this InfiniStar 700 ?
There’s no separate signal tube, but I can’t pretend I know exactly how it works
This is a rebranded version of the Folomov 18650S. Glad to see that they went with a NW tint. My 18650S has a WW emitter. Which, at least on my copy, the 219D was more of an ugly street light orange than a pleasing soft white. As far as the tail switch, I believe that the driver is actually in the tail. Thus, eliminating the need for a signal tube or wire. Review - Folomov 18650s
Thanks for your info.
Driver in the tail explains that unique e-switch. .
I have lost the back tailcap to this and cannot find it anywhere- do you know where I can? The company website is undergoing maintenance :frowning:
