✌ FREEME - ASTROLUX FT03 Mini OSRAM NM.1 510lm WRGB LED options USB-C 18650/ 18350 Flashlight - ALIVE
94 posts / 0 new
freeme
freeme's picture
Last seen: 16 min 13 sec ago
ASTROLUX FT03 Mini NM.1
OSRAM Colored  NEW USB-C 18650/ 18350 Flashlight
For reference, this is my order timeline for our Group Buy(1st batch).
Note: speed of delivery varies from country to country.
 ©freemex1thedeals.com
Group Buy Price: from $29.99!!!
Emitter: OSRAM NM.1
Brightness: 510 lumens
Beam Color: White/ Red/ Orange/ Green(brightest)/ Blue
Body color: Black / Blue / Green
Battery Type: 1* 18650 / 18350
Can't wait for our reply??
FLASH SALE Price: $32.99
Valid till:  BGFMSS
 WE NEED More SUBSCRIBERS!
Specification:
Brand & Model: Astrolux FT03 MINI
Material: Aluminum alloy
Emitter Type: NM1
Light temperature:
White
Red
Orange
Blue
Green
Output: 510 Lumens
Distance: 860 Meters
Beam intensity: 185,000 CD
Driver: Texas Avenger FET Driver with charging
Battery:
1x 18650 (not included)
or 1x 18350 (not included)
unprotected 18650 recommended, and
must use unprotected 18350 battery.
USB Rechargeable: Yes, Type-C (USB-C) Quick Charge
Reflector: High quality smooth reflector
Lens: Glass with anti-reflective coating
Body: Aerospace grade aluminium alloy
Button: Silicone rubber
Impact Resistant: 1.5 Meters
Waterproof: Equivalent to IPX7, do not immerse in liquids
Body Color: Blue / Green / Black
Weight: Approximately 136g without cells
Size: with 18650 tube:
144.8mm* 43.5mm* 25.5 mm
(length* head diameter* body diameter)
with 18350 tube:
113.7mm* 43.5mm* 25.5 mm
Package included:
1x Flashlight Head
1x 18650 body tube
1x 18350 body tube
2 x Spare Waterproof O-rings
1 x Lanyard
1 x User Manual
Operation UI:
Operate Current Status
OFF ON
Single click Low 1. Not at Turbo now: gear cycle
(Low - medium1 - medium2 - high, then return to low and continue the cycle to high)
2. At Turbo now, it will: return to the gear before the turbo
Long press Moon Off
Double click Turbo 1. Not strobe now, will go to: Turbo
2. If strobe now, will go to: Quick flash-SOS - Candle flash (and cycle)
Triple click to Strobe to Strobe
Four click Report voltage No reaction
Five click 1.If locked state now, will go to: Unlocked 1.If locked state now, will go to: Unlocked
2. If standby state now, will go to: Lock 2. If standby state now, will go to: Lock
Six click Tactical lighting mode
(this will be cancelled after power off)
No reaction
#forevercopycat
1thedeals.comyoutubeAstroluxNealsgadgetsolight
Edited by: freeme on 11/10/2020 - 12:38
freeme
freeme's picture
Reserved.
freeme
freeme's picture
Reserved.
freeme
freeme's picture
Reserved.
JordanZHP
Last seen: 1 day 13 hours ago
Interested! Thank you
sandro
Last seen: 1 week 1 day ago
Interested, thanks.
Majoroverkill
Majoroverkill's picture
I really like this but the lumen output is just to low. Sad
Doug S.
freeme
freeme's picture
For which color?
Majoroverkill wrote:
I really like this but the lumen output is just to low. :(
Majoroverkill
freeme wrote:
For which color?
All colors,
Doug S.
Tom E
Tom E's picture
Last seen: 2 hours 21 min ago
freeme - is the driver spec correct? Is it really a TA FET driver but limited to 4.5 4.8 amps? I'm confused. It's possible with firmware modifications but there are better solutions.
The output specs are clearly wrong - there are variances based on the color LED. I assume the specs are for white at 4.5 4.8 amps.
freeme
freeme's picture
Regulated driver at 4.8A max. Doubt it is TA FET driver design. I will ask them to update accordingly.
I hope they could provide accurate output for individual color as well.
Tom E wrote:
freeme - is the driver spec correct? Is it really a TA FET driver but limited to 4.5 amps? I'm confused. It's possible with firmware modifications but there are better solutions.
The output specs are clearly wrong - there are variances based on the color LED. I assume the specs are for white at 4.5 amps.
Tom E
Tom E's picture
Corrected to 4.8 amps above. If they can't provide color specific output levels, then they should just say the ratings are for white only, and if they say all colors are using 4.8 amps regulated output, then that's good enough for me smilewink
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 1 day 21 hours ago
When is the full sized version coming?
Friendlyfodder
Interested, thanks.
blueb8llz
Last seen: 10 hours 23 min ago
interested
freeme
freeme's picture
This one? http://budgetlightforum.com/node/71179
I believe they will only consider white nm.1.
casi29061965
Last seen: 1 week 8 hours ago
Interested in white and green lightcolour.
pearlriver
pearlriver's picture
Last seen: 8 months 1 week ago
Crazy good light
OrlyJr
Interested
casi29061965
Ordered three with green light.
Thanks for this GB, freeme !
TheAuditor
Last seen: 18 min 28 sec ago
I wonder if this will start shipping now? Says 22nd on BG
Bonum commune communitatis.
Yarp.
freeme
freeme's picture
Let double check with them this week.
TheAuditor
6th of October now.
Yarp.
Tom E
Tom E's picture
Green/green is Oct 16th frowncry
Tom E
Tom E's picture
So much for dates. Mine has been sterilized and shipped this morn smile
TheAuditor
Mine is now processing so that’s good.
Yarp.
freeme
freeme's picture
Green beam shipped.wink
Artiet59
Last seen: 1 hour 43 min ago
can I still get in on this price? green / green
Nevermind, green beam is GONE. wish I saw this before today, my fault.
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
d_t_a
Last seen: 6 hours 52 min ago
tried out 3 beam colors:
Astrolux FT03-Mini Osram white
Astrolux FT03-Mini Osram green
Astrolux FT03-Mini Osram red
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 3 days 27 min ago
d_t_a, I hope your bedroom is not next to that street, with engines revving all the time. Big Smile
d_t_a
The nearer building on the right side is a business-process outsourcing “BPO” (ie. call center that caters to calls from around the world), so it’s basically awake 24 hours.. (not seen in the video, upper floors are lighted at night)
