Tom_E
(Tom E)
September 10, 2020, 4:49pm
10
freeme - is the driver spec correct? Is it really a TA FET driver but limited to 4.5 4.8 amps? I'm confused. It's possible with firmware modifications but there are better solutions.
The output specs are clearly wrong - there are variances based on the color LED. I assume the specs are for white at 4.5 4.8 amps.
freeme
(youtube.com/@1thedeals)
September 10, 2020, 4:38pm
11
Regulated driver at 4.8A max. Doubt it is TA FET driver design. I will ask them to update accordingly.
I hope they could provide accurate output for individual color as well.
freeme - is the driver spec correct? Is it really a TA FET driver but limited to 4.5 amps? I'm confused. It's possible with firmware modifications but there are better solutions.
The output specs are clearly wrong - there are variances based on the color LED. I assume the specs are for white at 4.5 amps.
Tom_E
(Tom E)
September 10, 2020, 4:51pm
12
Corrected to 4.8 amps above. If they can't provide color specific output levels, then they should just say the ratings are for white only, and if they say all colors are using 4.8 amps regulated output, then that's good enough for me
When is the full sized version coming?
freeme
September 11, 2020, 2:47am
16
This one? https://budgetlightforum.com/t/-/60527
I believe they will only consider white nm.1.
Interested in white and green lightcolour.
Ordered three with green light.
Thanks for this GB, freeme !
TheAuditor
(TheAuditor)
September 22, 2020, 9:43am
21
I wonder if this will start shipping now? Says 22nd on BG
freeme
September 22, 2020, 4:21pm
22
Let double check with them this week.
Tom_E
(Tom E)
September 24, 2020, 2:18pm
25
So much for dates. Mine has been sterilized and shipped this morn
TheAuditor
(TheAuditor)
September 24, 2020, 3:03pm
26
Mine is now processing so that’s good.
ArtieT59
(ArtieT59)
September 24, 2020, 4:40pm
28
can I still get in on this price? green / green
Nevermind, green beam is GONE. wish I saw this before today, my fault.
d_t_a
(d_t_a)
October 1, 2020, 8:51am
29
tried out 3 beam colors:
Astrolux FT03-Mini Osram white
Astrolux FT03-Mini Osram green
Astrolux FT03-Mini Osram red
