Hello guys, today I would like to recommend an item that might be helpful for the current situation.
That is a garden lawn light, which can well work in the yard.
Details:
Polycrystalline silicon solar panel: 2V 100mA
Buzzer frequency: 400+/-50Hz
Effective area: 200-400 square meters
Charge for one day, works for more than 8 hours, pest repellent works for more than 24 hours
Solar energy, no wires required, energy saving and long service life
With 8 LED indicator lights, turns on automatically at night
Effectively repel cats, mice, foxes, raccoons, skunks, rodents, wild boars, minks, etc.
Check here to know more:2PCS Solar Powered Garden Lawn Light
LUMINTOP FW21 X9L is the pro pro model among all the LUMINTOP FW21 series.
Let’s see the details:
Voltage: 3.7-4.2V
Head diameter: 40.2mm
Tube diameter: 25.2mm
Lumens (max): 6500 LM
Waterproof: IPX8
Battery form factor: 21700
Flashlight modes: 5-mode
Details:
Voltage: 3.7-4.2V
Tube diameter: 25mm
Peak beam intensity: 10350cd
Built-in multi-function OLED display, can display various parameters
Built-in thermal control module will automatically adjust the brightness output to keep the unit from overheating
Impact resistance (1.5 meters)
Can’t wait to introduce IMALENT MS06 LED Flashlight
Let’s have a look at the excellent spec:
Details:
Utilizes 6 pieces of XHP70 2nd LEDs, lifespan up to 50000 hours with maximum output of 25,000lumens
Powered by three rechargeable 4000mAh 21700 Li-ion batteries
Instant turbo output by double press the power switch button while triple press the power switch button, can get lowest output
High efficiency constant power supply circuits will maintain constant brightness
Built-in thermal control module will automatically adjust the brightness output according to the working state and outer temperature
Combination of toughened ultra-clear mineral and anti-reflective coating glass
Aluminum SMD reflector
Aerospace-grade aluminum alloy body.wear-resistant Type II hard-anodized surface treatment
IPX-8 standard waterproof(2 meters submersible)
1.5m impact resistant
Tail stand capability
Head diameter: 56mm
Tube diameter: 51mm
Don’t forget to apply the MAP code to get the 33% off discount ,click here to enter:IMALENT MS06 LED Flashlight
25,000lms lol. Imalent flashlights are NOT worth there asking prices and they are nothing but problematic and there numbers are unrealistic. Good looking paper weight though.
The design is good looking, and functions are not bad, but if compare to the price, maybe what you say is true, it’s not exactly a high cost performance one, there are many alternative items at the same price.
We usually do site-wide 10% sale on some big holidays, or special offer for each category.
Here is the MAP coupon code collection which may have discount more than 10%: FastTech coupon code collection
