Well I hear you both. I sort of lean to luminarium iaculator's perspective, as I also prefer a luminous intensity rating because effective throw depends on the ambient light intensity, and also on our expected over the target light intensity.
However I also understand throw is directly proportional to the square root of luminous intensity, which means there is no direct linear relationship between intensity (candela) and throw (meters).
I do not think that is deceiving, as I understand it. The same applies for anyone knowledgeable in the matter with a minimum of expertise and/or mental agility. This is key.
I could also seriously mess with the way luminous intensity is defined, but overall I guess the actual problems and reasons are often rooted in common people's stupidity and caused by smart people pledging to their uneducated wishes.
Simon Mao will put one in a L21A with an 8 A driver soon and share the results!
Eager to know the results, if they are any good i will certainly buy some parts
That size reflector should see close to 450kcd max with this emitter according to my estimates… we’ll see what others get. I don’t think the 8A driver actually pushes 8A. If course without an output test done on these yet it’s hard to say how much is here on the table just with drive current. Also, I’m not sure how much time if any he put into optimizing focus. Does anyone else have experience with the 4040 gaskets? Are they as thick as the 3030s?
What’s the difference between CSLPM1 and CULPM1? Both are 2mm size emitters right?
I wonder if the current batch of M21A now accepts the slightly wider 21700 batteries (eg. Lii-40A and others). The earlier M21A won’t fit the Lii-40A (or Lishen 21700)
Exactly. The idea is that the larger footprint allows higher currents due to better heatsinking.
Osram’s datasheet says 6A, but since when did we use to stick with specs from datasheets?
We run cree LED’S on currents not even mentioned by Cree
I’m curious what the difference will be, since the surface area is 77,77% larger. (16mm instead of 9)
That means it can be abused a bit more (run higher currents) or sustain longer (better thermal dissipation/better performance)
I wonder if the rather small amount of more efficiency on CULNM1.TG / CULPM1.TG will be advantageous if used in a multiemitter array, e.g. underneath a quad optic. I hope to seeing some flashlights using CULNM1.TG underneath a Carclo 10621 optic anytime soon. Maybe Hank (KR4/D4v2) or Sofirn (IF25A) can offer something like this. Acebeam is using CSLNM1.TG (White Flat 1) in their TK16/TK18 lights.
