I still got one of those leak-detecting kits with UV dyes that you can add to oil, coolant, etc. Instead of a UVLED light, there’s a “gun” with 50W halogen bulb behind a silvered-glass filter. Blocks all VIS light and leaves only UV, like a ZWB2 filter.
Of course, I’d use one of my lights vs that beast, but…
Hi everyone, thanks for the efforts made thus far to avoid controversies and arguments in this thread. But it does feel like it’s going to start getting ugly. Please try to avoid the more controversial aspects of this topic, and don’t dig in your heels if somebody expresses a different viewpoint. Thanks in advance!
No word from me about the direct correlation of blue light = disease.
Otherwise we shouldn’t even expose or watch sunlight
But I have personal experience that cool/white lights can affect the sleep cycle more. And that it’s important for regenerate organism and endocrine system.
Remember when in my street replaced HPS bulb for white Leds.
Plus the introduction of cool white headlights on cars/bikes in the opposite lane, how much longer it took me to fall sleep than before. Same sensation of ‘’wake up’’ when I watched from afar 5000k Metal Halide instead the almost irrelevant Orange HPS Bulb at similar power.
And not good also watch TV,Phone etc… before sleep,maybe I’m sensitive.
Yes, I too think it’s about artificial light at night and breaking the natural cycle. Pure luck there are wavelengths not influencing release of melatonin.
What I don’t understand: Green is supposed to supress melatonin, right? When we watch yellow light, both red and green receptors are stimulated (else we wouldn’t see yellow), so the effect has nothing to do with receptors, or am I wrong somewhere?
The people you working with were most likely so tired they probably near the verge of falling asleep on shift. As others have mentioned, if you’re so tired, you can easily fall asleep in the middle of the day.
“Continued exposure to blue light over time could damage retinal cells and cause vision problems such as age-related macular degeneration. It can also contribute to cataracts, eye cancer and growths on the clear covering over the white part of the eye…Exposure to blue light before bedtime also can disrupt sleep patterns because it affects when our bodies create melatonin.”
And more from U.C. San Francisco. This is the research the dailymail used, so it isn’t the daily mail saying this. Although their reporting may be a bit sloppy; the meat of the issue and research is still there.
“Smartphone use directly correlates with sleep, with greater use demonstrating a significant association with shorter sleep duration and worse sleep efficiency, according to researchers at UC San Francisco…This was the first study to examine such use in a broad population, directly measuring screen time rather than relying on self-reported use. And, those with more screen time use had poorer sleep…”
I already got amber xp-e Led (not from KD) ~1$.
Placed by myself on single mode sk68.
Be aware the real color to my eyes look more washed
and less saturated than photo.
Don’t like,I would try another more deep Orange native if it exists.
Let’s be honest; are we REALLY willing to give all CW emitters? And what if it turns out that ALL artificial light has the same effect? What constitutes non-“blue” light? How WARM does it need to be?
If the reason for using Amber emitter is to avoid blue light, an E21A 2000K 90CRI would be a good option. It emits minuscule blue wavelength but you still get to see everything in glorious hi fidelity color. It’s a much more practical choice for daily use.
I think brightness also plays a role. Low lumens means less of whatever percent of blue light might be coming out of an LED.
it would help to have data on the percent of blue light in various LED options at each step in CCT
iow 4000k probably has more blue light percentage than 3000k…
another factor in blue light reception, is the brightness at which the light is used
even a cool white LED, used at sublumen levels, moreso at scotopic levels (below 0.01 lumens, when we cant see colors), would be producing blue light in very low quantities…
makes me wonder if below a certain lumen level, even cool white can be used without degrading Rhodopsin…, and also without degrading Melatonin?
blue light factors to quantify
intensity (more lumens means more blue light)
spectrum (higher Color Temperature means more blue light)
reactions to monitor
Rhodopsin (more blue light means less of that hormone)
Melatonin (more blue light means less of that hormone)
What benefits make some people want Amber?
We know Red is better at preserving Rhodopsin and Melatonin.
