[Video + Written Review] Olight Warrior X Turbo (1000 Meters of Throw, 250,000 Candela, 21700 Rechargeable Battery)
5 posts / 0 new
liquidretro
Last seen: 3 weeks 4 days ago
Today I have Olights new thrower flashlight, the Warrior X Turbo. It’s capable of 1000 meters of throw on 1100 lumens and 250,000 candella. It has an Osram LED, and is compatible with the pressure switch from the Olight Odin. Thanks to Skyben on Amazon for sending this to me to look at and review.
Watch this review on YouTube:
***Follow me on Instagram:* https://www.instagram.com/liquidretro/
Join the Facebook Page: https://www.facebook.com/LiquidretroReviews/
Packaging & Accessories
I won’t go into much detail here but the Warrior X Turbo has great packaging, arguably Olight has the nicest packaging in the production flashlight world. The light comes currently as two colors, you have the black model that I have here and then Olight does offer a limited production gunmetal gray as well. As a base package the light comes with a 5000mAh proprietary 21700mAh battery. Fun side note I will link to a video another flashlight reviewer did of how they make these batteries. You also get the latest generation of the MCC charging system, a Tactical Grip Ring (TGR), pocket clip, anti roll ring, lanyard, and a nylon holster.
Construction
The Warrior X Turbo takes a lot of the design cues from the Olight M2R Pro, in the tail cap and body, adapting them to the larger thrower platform. Overall build quality is great for a production light. First the more aggressive tail button is here, which does allow the light to tail stand but it’s not the most stable when doing so. The tail is also compatible with the locking remote switch from the Olight Oden so if you have that it works here great. Inside the tail is a spring loaded contact internally.
Threads on the body are anodized, nicely greased and have a double oring system, to interface with the anti roll ring and the TGR. I will talk in detail about the clip in the retention section. The grip on the body is the same as what was on the M2R Pro, a more aggressive triangle, and has a few flats milled in for labeling.
The head is glued to the body and really grows in size to accommodate the large smooth deep reflector. I like the relief that’s milled in to give it some more style and save weight. The front bezel is beefy with large solid crenulations that allow light the light to stand on its head and for light to spill out. It’s not glued in place and can be removed with some force. This does effect the beam shape on the outer edges. The lens is large and anti reflective coated.
Size & Weight
I measured the length at 159mm, maximum diameter at the head was 58mm, minimum diameter on the body was 26.2mm. Weight with the battery, clip, standard anti roll ring came in at 296.1g. Here are a few pictures of the light with a few similarly sized lights you might know.
Retention & Grip
You have a couple of retention options for the Warrier X Turbo, it does come with a captured pocket clip, but it’s 38mm from the top of the light. That’s ok because with the size of the head here, your not going to be EDCing this in a pocket. The captured clip is nice, it won’t rotate because of an extra tab in the clip and on the light and anti roll ring.
The stock anti roll ring allows you to use the standard cigar style grip without problems, but that can be a little uncomfortable so Olight includes a Tactical Grip Ring (TGR) that’s a softer silicon like material that slips on in its place.
Other options include a lanyard that’s included, and the included holster thats purpose built for this light. It has a velcro belt loop and plastic D ring.
LED & Beamshots
Olight doesn’t say which LED is in this light officially, but they do list the tint at 6000-6700k, and by looking at it my guess is it’s one of the OSRAM models we have seen in other popular throwers. I wish they would list the LED they are using like almost every other manufacturer does. It’s a cool tint but not blue. The beam has a small but very intense hot spot, possibly one of the tightest I have had in recent times. There is a spill but it’s very minimal, only a few percent of the center, and there is some distortion on the edges from the shape of the outer bezel that’s noticeable at short range. I didn’t measure any PWM on this light on either mode.
Runtime & Heat
The ability on the Olight Warrior X Turbo to sustain it’s turbo output was better then I expected. From start to full and stable step down was right at 9 minutes, and it stayed above 80% relative output for the first 6 minutes. At that point it was running at 50% relative output for 1:45:00. Total runtime was just shy of 3 hours. The good news is with such a tight beam even at the lower output throws pretty well. When the power level reaches 20% the light starts to vibrate every 5 minutes to let you know, when it’s below 10% it will vibrate every minute, and below 5% it will vibrate every 10 seconds. You can’t miss it especially if mounted on a firearm. Maximum heat I saw was 48C at the 9 minute mark. LVP was measured at 2.95V.
UI
The UI here is super easy, it’s a 2 mode light with momentary and full on tactual switch. Low is rated for 150 lumens and you can use it in momentary if you half press the button and hold, or a quick have press will lock it on. A full press gives you full power 1100 lumens before step down and a quick press will lock it on, or a full press and hold will work in momentary. It’s the same UI we have seen in other tactical Olights with a rear switch. This light also works with the pressure switch from the Olight Odin.
Recharging
I had a little bit of trouble recording the graph with the Warrier X Turbo with my equipment due to the spikes along the curve where the current drops very near zero which tricks the measuring tools, but overall charge time here was 5:30:00, and the maximum charge rate I saw was 1.92A. I measured the full battery at 4.172V. No concerns with the charging but I will have to look for a firmware update for my equipment.
Pro’s
  • Long runtime for “Turbo” Nearly 10 minutes.
  • Great build Quality
  • Despite being cool white it’s not obnoxiously blue in tint
  • Options to mount/cary/activate
Con’s
  • Tail magnet is only for recharging & the pressure switch, it’s not strong enough to hold the weight of the light.
  • Proprietary Battery
  • A little on the pricy side
  • Two modes are ok, 3 might make it a little more useful for more then a weapon light.
Conclusion
The Warrior X Turbo is a nice more compact thrower from Olight. It has almost as much power as the much larger, more expensive Javalot Pro, but in a size thats easier to use, and carry on your person. While this is designed as a weapon light with the compatibility with the remote pressure switch and to beagle to be mounted on a weapon, it also works pretty well as a super easy main thrower. To me the long 6-9 minute runtime on Turbo is hard to beat in many other thrower style lights in this price category.
It’s an Olight so it has the usual caveats, like the proprietary battery, and the cooler tints. If you are less sensitive to those things I can recommend the Warrior X Turbo as a pretty sweet well built thrower.
Edited by: liquidretro on 09/14/2020 - 22:59
Rusty Joe
Rusty Joe's picture
Last seen: 15 hours 3 min ago
The same button for low and high, some have said, is annoying since its harder to manage going from low to high with shakes hands.
Rusty Joe
Rusty Joe's picture
Good review.
2A
great review, thank you!
liquidretro
Ya I could see that being that way, there isn’t much travel in the button and it’s pretty heavily sprung.
