Can’t wait to introduce IMALENT MS06 LED Flashlight
Let’s have a look at the excellent spec:
Details:
Utilizes 6 pieces of XHP70 2nd LEDs, lifespan up to 50000 hours with maximum output of 25,000lumens
Powered by three rechargeable 4000mAh 21700 Li-ion batteries
Instant turbo output by double press the power switch button while triple press the power switch button, can get lowest output
High efficiency constant power supply circuits will maintain constant brightness
Built-in thermal control module will automatically adjust the brightness output according to the working state and outer temperature
Combination of toughened ultra-clear mineral and anti-reflective coating glass
Aluminum SMD reflector
Aerospace-grade aluminum alloy body.wear-resistant Type II hard-anodized surface treatment
IPX-8 standard waterproof(2 meters submersible)
1.5m impact resistant
Tail stand capability
Head diameter: 56mm
Tube diameter: 51mm
Don’t forget to apply the MAP code to get the 33% off discount ,click here to enter:IMALENT MS06 LED Flashlight
25,000lms lol. Imalent flashlights are NOT worth there asking prices and they are nothing but problematic and there numbers are unrealistic. Good looking paper weight though.
The design is good looking, and functions are not bad, but if compare to the price, maybe what you say is true, it’s not exactly a high cost performance one, there are many alternative items at the same price.
We usually do site-wide 10% sale on some big holidays, or special offer for each category.
Here is the MAP coupon code collection which may have discount more than 10%: FastTech coupon code collection
Today’s cool guy! JETBeam 3Ms Tactical LED Flashlight
I don’t know, I just love the appearance。
Details:
Battery capacity (MFG rated):5100 mAh
BAattery feature:Rechargeable
Battery form factor:21700
Estimated usage time:1.9 Hours (Turbo)/120 Hours (Moonlight)
Waterproof:IPX8 (Submersible to 2 Meters)
Lumens (MAX):2000 LM
Color temp range:5000-6500K
Light source color:6500K
A great new arrival! Niwalker ES2 Dual Head LED Flashlight
Max output 7050 lumens
Max beam range 215m
Waterprood IPX8
Different color options
Dual head
neutral white & UV
Today’s not new but not bad items from FastTech: 2-in-1 Bike Front Light Bicycle Headlight Bike
Features
5 lighting modes
Powerful headlight - 1 super bright main light beam, 2 fog lights and 2 side lights
5 display modes, multifunctional and intelligent
Waterproof, can be used in rainy days
5 sound modes, smart anti-theft alarming mode
USB rechargeable headlight. (The taillight has 2 button cell batteries included and can’t be charged. There’s an insulator between the batteries and needs to be taken out before you use the taillight.)
Flexible rubber strap design fits most handlebar
