Sofirn SC31 PRO, New Anduril Flashlight
360 posts / 0 new
Zappaman
Zappaman's picture
Last seen: 17 hours 19 min ago
I’ll buck the trend and say my favorite “small” Anduril Sofirn light is still the IF25a. I feel bad I broke the first post on it without a proper review— just 4 months ago BTW. It is SHORTER than the SC31 Pro by about a 1/2” and not much heavier or wider than the SC31 Pro… and it runs on a 21700 high capacity (4800mAh) battery VERY nicely Wink
That said, I have TWO SC31 Pro lights with another (5K) due any day now. It really is a super light and worth all the good feedback we are seeing here. But aside from a front pocket (tight) tuck light where the SC31 Pro is a natural “fit”… given a choice- I’d take the IF25a over the SC31 Pro in the 6.5k model (where I’d use it outdoor).
For INSIDE light… I am thinking I’m going to really like the SC31 Pro in the 5k when I finally get it and in that capacity it may “trump” (no political pun intended I assure you) the IF25a for that use. Oh yes, I DO have the IF25a in the 4k and it’s a great beam of natural light for sure… I’ll know which I prefer when I get the SC31 Pro 5k in and compare.
ZappaMan
maniakman
maniakman's picture
Last seen: 12 hours 20 min ago
Eagerly awaiting to receive my shipment of both versions (5k and 6.5k).
Absolutely love the feature of the programmable AUX LED on my Sofirn BLF SP36 & IF25A.
Also love the breathing AUX LED on the non-Anduril SC31B.
Has anyone changed the clip to the Astrolux S1/BLF A6 clip  that could post pictures?
McCatface
Last seen: 7 months 1 week ago
Would LH351D 4000K be a suitable emitter if I switch the whole MCPCB?
maniakman
maniakman's picture
Received the 5k version today.
  • Battery arrived @ 3.9V (tested via Multimeter ) and flashlight blinked out 3.9V as well.
  • USB-C plug seems well aligned.
  • Temp check was a bit low so I set it via Thermal Config.
  • Programmed the switch LED to heartbeat (printed manual does not show how,- the Anduril UI forum post comes in handy).
Overall, looks like this will be my new EDC.
Only complaint is the clip, – make it a deep carry clip and this is a perfect 1×18650 light in my book.
Now wondering if the Wurkkos FC11 tube can be used (seems more pleasant to hold)….
McCatface
maniakman
maniakman's picture
Nice, Thanks @McCatface !
Nachtfeuerzeug
Nachtfeuerzeug's picture
Last seen: 3 weeks 1 day ago
I've had it recommended to me that 6 amps is too much for that LED. I measured 5.7A with a fresh 35E. Read Texas Aces review for more info.
EDC
FW3A, SST20 4000K || S21A, Crescendo Mtn20DD, LH351D 4000K || SP32A, SST40 5000K
Recent/ongoing Mods:
S2+, TexAven 17mm, LH351D | S21A, Crescendo 20mm, XPL HI 5000K | L2 w/Mtn17DD Zener Guppydrv, XHP-50 | C8+ OP, DD XHP-50
SP32A w/SST40 5000K | TIR Upgrades | EagleTac clip | Ultrafire C2 w/6A 20mm & LH351D | S2+, Biscotti, Nichia 219C 2700K |
Reviews:
Sofirn SP31 v2.0 Tactical Flashlight (Cree XPL HI) || Sofirn SD05 Scuba Diving Flashlight || Sofirn SC31 USB Rechargeable (XP-G3) || Sofirn SC31 Pro 5000K
how crazy is this
Last seen: 15 hours 40 min ago
Just got the light yesterday. Very impressed! Would like a warmer tint but the 6500K version is OK if a bit on the cool side for me. Andruil is very nice.
AFIK, the default moonlight is the lowest. I believe I also configured it for 1. Still a bit high for a moonlight for me. That is my largest complaint.
I said this was going to be my last flashlight for a long time;-) OTOH, I may have to go for a 5k version and gift this one. It really does everything I want.
Can’t wait for someone with the equipment to do a full review with output and run time charts!
Does anyone know how reliable the thermal regulation is? Was playing with it last night and left it at the top of the ramp for a couple of hours or so. Seemed to be fine. A rather amazing amount of light for a great run time. Would like to see what it looks like in a chart. My eyes are easily fooled. That said I think that the top of the smooth ramp is truly a remarkable achievement. Seems to me that it gets sustained significant output on par with much larger lights that have better heat dissipation.
Nachtfeuerzeug
Ramping mode moonlight is lower than stepped.
EDC
Reviews:
McCatface
Nachtfeuerzeug wrote:
I’ve had it recommended to me that 6 amps is too much for that LED. I measured 5.7A with a fresh 35E. Read Texas Aces review for more info.
Any other compatible Hi CRI emitter options?
Nachtfeuerzeug
I'm going to try this LED myself (in a different light, though). It appears to be quite durable.
EDC
Reviews:
how crazy is this
Yea that is the great thing about andruil. At first I kept if off stepped mode because of that. Now I have it so that the floor is the same in both and use stepped.
Nachtfeuerzeug
It IS awesome! I've tinkered with it a bit.
I can't wait till Anduril, in lightning mode, can transmit simulated thunder to my home theater sound system!!!
EDC
Reviews:
GDF
Last seen: 3 days 2 hours ago
I wanted to test a TIR on SC31 Pro but so far the bezel is not budging. I have some lid grip rubber pads that usually do the trick, but not this time. I don’t want to resort to tools that will mar the finish. I also tried heating up the head to 70C by removing thermal limit, in case the heat would help break the glue. Still wouldn’t budge. Any other suggestions? Stupid glue…
Tom E
Tom E's picture
Last seen: 17 hours 17 min ago
The pine board method works well - I removed several bezels using this technique that I couldn't budge with other methods. This light probably could be done with one board and a strap wrench. But I would try the "gloves" first. The gloves worked for me with this light in breaking the blue glue seal. Think I bought mine at Lowes - this is my 2nd pair, first pair lasted a few years:
This one goes back to 2014:
This is a variation used of the pine boards for a GT Micro:
Here's a post in the mod thread from 2017 describing/showing the pine board method: http://budgetlightforum.com/comment/1143001#comment-1143001
Swabs
Swabs's picture
Last seen: 4 weeks 13 hours ago
Received a SC31 Pro this morning. It is the 6500K version. Looks like I will carrying this one a lot, another great Sofirn torch.
My Future's So Bright...well, my flashlights are anyways.
GDF
Tom E wrote:
The pine board method works well – I removed several bezels using this technique that I couldn’t budge with other methods. This light probably could be done with one board and a strap wrench. But I would try the “gloves” first. The gloves worked for me with this light in breaking the blue glue seal. Think I bought mine at Lowes – this is my 2nd pair, first pair lasted a few years:
Here’s a post in the mod thread from 2017 describing/showing the pine board method: http://budgetlightforum.com/comment/1143001#comment-1143001
Nice, I’ll try gloves first. I’ll probably pick up some strap wrenches too. Looks like they can come handy for several tasks
Nachtfeuerzeug
This A6 clip holds the light tight although it's not 'square' to the light and even teeters when clipped to a thick material. Positioning the clip tip on the charging port cover keeps it down and inside the pocket & improves retention. It's better to pull the light away from pocket then slide out v's just sliding it so as not to displace the rubber cover.
I prefer the clip style of a Nitenumen light (although probably not the originator of the design)
EDC
Reviews:
Nachtfeuerzeug
Can't wait for someone with the equipment to do a full review with output and run time charts! Does anyone know how reliable the thermal regulation is? Was playing with it last night and left it at the top of the ramp for a couple of hours or so. Seemed to be fine. A rather amazing amount of light for a great run time. Would like to see what it looks like in a chart. . Seems to me that it gets sustained significant output on par with much larger lights that have better heat dissipation.
Here it is from turbo (I just read your post closer and can run it at top of ramp later). This graph is adjusted to what manufacturer says is the max output:
I haven't adjusted the temperature setting as it came to me. I believe step-down is around 39 degrees Celsius.
EDC
Reviews:
Vamko
Sofirn SP10S (left) and Sofirn SC31 Pro 6500K (right). SC31 Pro looks a bit greenish on the picture, but it is not.
Sofirn SC31 Pro 6500K.
Probably somebody would like to share a beam picture for SC31 Pro 5000K. Would be very interesting to see how 5000K tint looks.
BLF-L
BLF-L's picture
Last seen: 6 months 1 week ago
Vamko wrote:
… SC31 Pro looks a bit greenish on the picture, but it is not.
+1
Thanks for sharing the beamshots Thumbs Up
Really appreciate that.
I’m still waiting for my SC31 Pro to arrive.
TimMc
TimMc's picture
Last seen: 49 sec ago
Sofirn SC31 Pro SST40 5000K arrived today! I swapped the 18650 tube and tail cap with an 18350 tube and magnetic tail cap.
Time to learn how to use Anduril. Smile
Sofirn SC31 Pro SST40 5000K turbo with KeepPower IMR18350 1200mAh (left) and Lumintop Tool AA 2 NW max with LADDA AA (right)
Vamko
Thanks for sharing beamshots! SC31 Pro 5000K looks cold in turbo.
TimMc
TimMc's picture
Left to right:
Manker E02II SST20 4000K with Vapcell INR10440 set to max;
Sofirn SC31 Pro SST40 5000K (?) with KeepPower IMR18350 set to turbo;
Lumintop Tool AA 2.0 219C with LADDA AA set to max;
Sofirn C01S SST20 4000K with LADDA AAA set to max.
Left to right:
EagTac T25C2 XM-L U2 CW with EagTac 18650 3400mAh set to max;
Olight i3T with dc-fix and Vapcell INR10440 set to max;
Sofirn SC31 Pro SST40 5000K set to turbo;
Manker E02II SST20 4000K with Vapcell INR10440 set to max.
I’m not sure if I’ve got 5000K or 6500K.
TimMc
TimMc's picture
My old Sony RX100II camera thinks the hot spot is about 4500K and the outer bit is 5300K for the Sofirn SC31 Pro 5000K on turbo.
Vamko
Thanks for sharing more beamshots!
I quess it is SST40 5000K. As far as I know, the SST40 5000K starts at around 4000K in low modes, and becomes colder when you ramp it up. So I think it is fine that in turbo it looks colder.
TimMc
TimMc's picture
I added some dc-fix and the beam now looks much nicer. Smile
TimMc
TimMc's picture
Is the SC31 Pro safe to use to charge KeepPower IMR18350 cells?
500mA to 1000mA charge current? Terminates at 4.20V?
TimMc
TimMc's picture
ZL SC64c LE, SC31 Pro, GA
Nachtfeuerzeug
TimMc wrote:
Is the SC31 Pro *safe* to use to charge KeepPower IMR18350 cells? 500mA to 1000mA charge current? Terminates at 4.20V?
I think you can do that with a 500 mA USB power source. Don't use a quick charger. You might have an older phone charger sitting around.
EDC
Reviews:
