I want to almost completely because i am so curious after reading everything n here from people that know so much about color “temperature” (I don’t know if thats even the right term). but yea, a 2000k mule sounds awesome.
That doesn’t sound right. E21A (except possibly mules) should be limited to 5A current, XP-L HI should consume more than 10A with a decent battery.
Is either one of your E21A flashlights a mule?
Did you calibrate the temperature sensor on all flashlights?
Is the temperature limit set to the same value on all flashlights?
Yes, the D4v2 has less thermal mass than the KR4, so it heats faster.
Edit: at the same power levels
If one light is running at a higher power level than the other, like a direct-drive XP-L HI vs a regulated E21A, the higher-power one should heat faster. Because 20A of power vs 5A is a much bigger difference than anything caused by the LEDs or the small difference in host size.
I’m not sure about the kr drivers, but recently I bought a couple d4sv2 drivers from hank without any issues. Just send him an email and see if hes willing to sell them to you.
Good instinct . I did a test with 2 fresh 30q on 2 d4v2 ti . One with xpl-hi 5000k, the other with a mix of e21a’s 3500 and 5000k . Top of the ramp . Fingers on the copper . The xpl-hi gets hotter faster and seems to cut the power sooner . I did a second test holding a kr4 ti and a d4v2 ti, both with e21a’s . The kr4 is an easy winner . I’m using 30q’s from a single purchase but they seem to have different power . I will retry those test switching batteries .
The D4v2 E21A driver isn’t actually a KR4 driver. It’s just … electrically compatible. Same logical design, but different physical design. An actual KR4 driver would not fit into a D4.
Yes, I merged lighted switch support into the KR4 firmware, so it can be used on the D4v2 Ti with E21A.
Originally I had a separate “D4v2.5” firmware for it, but the only difference from KR4 was the lighted button… so I merged them together. I don’t think I ever published new .hex files for it though, so the most recent ones on my site are still d4v2.5.
Just make sure to use the noFET version. The FET can destroy the E21A LEDs very quickly, so it should not be enabled.
That’s good to know, thanks. Hank said the driver has a diameter of 22 mm, and I gather it essentially runs the KR4 firmware. I’m guessing that means regulation is equal, there is a FET present (but probably disabled by default), and it can be reprogrammed using Hank’s kit?
That would be the most relevant things for me, hardware-wise.
XP-L HI can make about 4000 to 4500 lumens at about 15 to 20 Amps. E21A stops at 5 Amps and maukka measured it at about 1200 lm.
The main appeal of E21A is that it’s high-CRI with a nice tint and a variety of good color temperatures. The clear optic isn’t optimized for E21A though, so it uses a floodier frosted optic instead. It’s a close-range flooder for high-quality illumination.
XP-L HI is more throwy and makes a lot more lumens.
