Nealsgadgets - Lumintop Micro Gt - 809m Osram
11 posts / 0 new
Cesconetto
Cesconetto's picture
Last seen: 1 day 17 hours ago
Gostaria de saber se alguém já tem ou viu algum rewiew dessa Lumintop com Osram para compartilhar mais detalhes. Smile
https://www.nealsgadgets.com/search?type=product&q=micro+gt&variant=3228...
Th558
Th558's picture
Last seen: 11 hours 34 min ago
Is it really 809m?
Lexel
Lexel's picture
Last seen: 11 months 2 weeks ago
809nm for pumping Nd:Yag laser crystals—> green beam if a KTP is used!
MoreLumens
MoreLumens's picture
Last seen: 11 hours 9 min ago
Has anyone get that? Beamshots? What else is different compared to regular GT Micro? Is the driver same and how hard its swap XP-L Hi to white flat?
JaredM
JaredM's picture
Last seen: 58 min 6 sec ago
I find it hard to believe it’s making 164kcd.
Even V54 only claims his mod to be 140kcd, and his values always seem like a bit optimistic (turn on) values.
If it is I’ll buy one and eat my words, but that’s gotta be a magical reflector that all others must copy.
dave1010
dave1010's picture
Last seen: 2 hours 53 min ago
Translation of the first comment:
Quote:
Cesconetto: I would like to know if anyone already has or saw a review of this Lumintop with Osram to share more details.
If you’re just catching up, the original GT micro has an XP-L and throws about 500m. This one has an Osram W1 (I think) and supposedly throws 809m. Vinh’s modded GT micro has a W2.1 and throws 693m.
BT100
Last seen: 1 day 21 hours ago
V54 version uses w2.1. Neals version uses w1.1.
SKV89
Last seen: 8 hours 22 min ago
Neals version uses the CSLNM1.TG which is the W1. CULNM1.TG is W1.1. There’s no way this light can throw anywhere 809m. But it will still be the best thrower for its size.
JaredM
JaredM's picture
Vinh tested with the W1 and only saw 140kcd”:https://www.candlepowerforums.com/vb/showthread.php?456965-BLF-GTvn-Micro&p=5294231&viewfull=1#post5294231
JaredM
JaredM's picture
Anyone with a measurement here yet?
sarge12
Last seen: 3 weeks 1 day ago
I have 2 of them…1 aluminum, 1 brass. I have no way of measuring, but it has amazing throw from such a small light. It seems to throw almost as far as my Astrolux FT03 SST40-W which claims 875 meters, albeit at lower lumens. I actually like the aluminum on best because the brass is very heavy for it’s size. The aluminum one, I can actually put in my shirt pocket. I also have the non-osram led model, but the osram version throws much further.
