Congratulations! :+1:
I got this:
I got this:
Congrats! Happy moonlight mode years.
Got my XT45 yesterday! It is an impressive flashlight for the price. The light output is great but man does it get hot quickly! it gets hot quicker then my NSX3A! The UI is a bit funny. I keep it on low when off and the next mode after low is high them medium, double tap for turbo then triple for strobe. Its stepping down after 20 seconds. The size is almost identical to my C8+ but a tad shorter. Its much nicer looking then the C8.
WOW
Beautiful, from where did you get this? Link?
It’s a Sinner Customs light, bought it directly from them. He doesn’t have a site but he has an Instagram.
Nice score!
I’ve been wanted to have one of Sinner’s creation since he was only build a custom host.
Is it the Reylight AAA Ti?
Yes it is. The Pineapple Ti Mini. Not really a budget light in general but pretty budget for being Ti and small batch. My first Ti light so I am very happy. The Nichia 219B 4500K R9080 high CRI is very nice
Sandblasted Ti always looks amazing.
Great looking flashlight and LED Bak!
A Sofirn C01R and Convoy C8+. Both are excellent!
A tub of o-ring-friendly silicone grease. Immediately picked up an old toothbrush and went at it on the threads of all my older lights. Convoy S2, Thrunite Ti3, Lumintop Tool, you name it. It’s insane how smooth and nice the threads feel now, some are even smoother than they were out of the box No more squeakers either.
Yep, that’s why (as long as I’m motivated enough), I’ll scrub down even “well-lubed threads” and even pull off and clean O-rings and the grooves they sit in, and relube everything from scratch. Buttery smooth…
People forget that even the aforementioned “well-lubed threads” is they they’ve just been machined and anodised, and can have leftover grit, etc. embedded in them and in the lube. And it just wears with each unscrewing/rescrewing. Scrubbing-down and relubing gets rid of it.
That’s why sometimes squeaky unlubed threads can be better, as it forces you to do that (or just live with grindy threads).
+1 to you Next time I go on a re-lubing spree, I will remove the o-rings to give them a very good slather. The TN12 I gave to my brother sure could use that treatment after more than 5 years of use.
I got my tires rotated at a Mavis tire center. Found a free coupon on their web site . During the rotation they inspected my 2012 MDX with 57,000 miles and said my tires needed replacement (It’s a second set with 20,000 miles on them). They also claimed my rear shocks were leaking oil into the cylinders (whatever that means), and I should replace the front struts at the same time . Oh and I would need an alignment to go along with the shock and strut change .
Wow. Were you wearing a teeshirt that said “The Muggle” on it??
