Thanks for confirming! And that’s bad news - the very next thing I was going to do is move these sst20/biscotti into older heads to I can use the short tubes with them!
I asked for short tubes that match the new threads, I’ll report back when he replies. If someone else could ask too that would be great. He’s kind of brief in the amount of information he provides.
Thats sad, that was exactly Convoy’s strong point, everything LEGO’d with eachother unlike other chinese brands with varying material quality and different assemblies, threads and so on.
Hopefully Simon will get rid of that bad batch and go back to his old good quality and interchangeable parts.
Any idea this was done intentionally? Or was it accidental and now Simon is forced to fill up a hole with another hole (Dutch expression).
If the threads on the tube are wrong, you need a head, and a tailcap with the same (new) threads.
And because the pill screws into the head like the tube does, also a new pill with the same threads.
I remember something similar. Parts of the new BLF A6 were intended to lego with the BLF EE X6.
It was said that a first batch of a certain part was made with wrong dimensions, and the production of the other part were re-designed to fit that first batch.
Was it due to some machining that require a new tool or am I spewing nonsense?
I know how some knurling was different because they replaced a new wheel but then again I know nothing about aluminium machinery and how they make threads
I’ve bought the last piece of the first Cu batch. Threads are fully identical to the existing Alu ones.
Does NOT mean threads of the second Cu batch is identical to those of the “new” aluminum S2+.
I ordered two S2+ on 2020-08-09, nit arrived yet. One is with XPL HI 8*7135 Biscotti. The other is SST40.
It’ll be “interesting” to see the threads of both !
I assume the XPL HI has old threads and the SST40 has new threads?
So they won’t LEGO with each other?
Or they both have new threads?
Then they certainly won’t LEGO with my old S2+
btw, My old S2+ are from 2017 and 2018 .
I’m very sorry, because we need to use a standardized mold, all the threads have to be changed. The molds used before are all hand-polished.
Before that, I also realized that there would be many problems,
Thanks for the info Simon.
So basically this change of threads specification is due to new production/manufacturing process which is more efficient, and not caused by some random mistakes in the machining department?
If that’s the case here, then I’m personally OK with that, as long as each flashlight is fit properly and works well, and this change is as planned and designed, therefore it is consistent for current and future batches . More efficient production process is good.
