Test/review of LiitoKala 26700 4000mAh Lii-40E (Orange)
Official specifications:
  • Battery Type: Rechargeable Lifepo4
  • Nominal Capacity: 4000mAh , Real
  • Nominal Voltage: 3.2v 3.3v
  • Battery Dimension: 26.5x71mm(±0.02mm)
  • Battery Weight: About 93g
  • Internal Resistance: less than 20 mohms
  • Cycle life: More than 2000 times, DOD at 80%
  • Input Charging Voltage: 3.65v/cell
  • Input Charging Current: 2A
  • Continuous Discharging Current: 3C
  • Max Current Discharge: 5C
  • Discharge cut-off Voltage: 2.50v/cell
  • Charging Temperature: 0°C ~ 45°C
  • Discharging temperature: –20°C ~ 60°C
  • Storage temperature: –20°C ~ 45°C
A LiFePO4 in 26650 size with fairly good capacity.
The two cells matches very nicely and can deliver the rated 3C or 12A.
Conclusion
This is a good LiFePO4 battery and as usual for this type it has very stable output voltage and less energy contents than the more common LiIon types, but longer life.
Notes and links
The batteries was supplied by a reader for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Around 2/3 the energy density to weight ratio versus a Power Long Battery 26650 NMC cell (LiitoKala Lii-50A, for example). I wonder who makes these, seem very suitable for e-bike or other sort of short range / urban vehicle batteries with high cycle life, for example. They feature a small voltage depression at ≈70% DoD and on, I'd say that is intended to ease the life of battery SoC measurement electronics.
They can be purchased in their genuine wraps here and there (for example):
Thanks HKJ!
Thank you for the review of these cells.
I have built a 12V (4S) battery pack with these cells, and it works very well.
This is the BMS used for the battery pack: https://nl.aliexpress.com/item/32976068743.html?spm=a2g0s.9042311.0.0.27424c4dut8iGD
I use this charger: https://nl.aliexpress.com/item/32866007777.html?spm=a2g0s.9042311.0.0.27424c4drg1UCx
