I ordered 2 supposedly 10amp 26350s from Mountain Electronics a while back for my E10. Obviously the E10 doesn’t pull 10 amps so I don’t know if they a really are, but that’s another option.
Hi, I have both D4s and D4sV2 with the same leds, XP-L HD V6 3D, but the ones in the D4sV2 are colder, like 6000K maybe? Can this be a variation over tints in same leds or may I have a different led version?
In the boxes both of them state the same leds.
D4s left, D4sV2 right, both with fresly charged Vapcell 26650s.
Looks like the same CCT to me but the D4Sv2 has a much nicer tint. Greener tints can tend to have the effect of appearing as a lower CCT than they are.
Tint is kind of a lottery as to what you get, and it looks like you got a good one with your D4Sv2.
I also have a D4S XPL-Hi 5000k and D4Sv2 with XPL-Hi 5000k. But in my case, the D4S XPL-Hi 5000k seems to look a bit “nicer” to me than the D4Sv2 XPL-Hi 5000k.
Likely CCT.
In your case, I like the tint of your D4Sv2 better since your D4Sv1 has a bit more “greenish” hue.
You guys have me wanting to buy a “warmer” D4SV2. I got the 6500K and I’m just dipping my toe in the “warmer temperature” flashlight water. Hank is my favorite seller and I have a 2000K Noctigon KR4 coming
Jealous, I only have one light that is warm, the 4000k sst20 fw3a. It’s a beautiful tint and also the first real light I bought (6 months ago), now I want the 2000k kr4. My 5000k kr4 is my most used light out of my 20 or so flashlights. Love everything about the kr4, and 2000k just sounds so different, extreme (?) and interesting.
Yeah I’m pumped! I’ll let you know what I think of it when it arrives and take some pictures of the beam if I can figure out the best way of doing that. It seems like when I take a photo of a flashlight beam with my iPhone it never looks like reality
I wanted a wider beam for my D4Sv2 as I mostly use it in tighter spaces indoors or underground so it’s nice to have a wider and more diffused beam. The standard ‘floody’ optic offered by Emisar with 20 degree beam angle was much better than the normal one but was still a bit narrow for my taste, especially when taking videos lit by the torch.
It turns out LEDiL also makes optics in the same style in both 25 and 30 degree angles, so I ordered some of each to test. They work really well in my torch and I now have the 30 degree one permanently installed; I think it’s a great balance between light spread and intensity, because there’s still directionality in the beam and a central spot, but at the same time you get a really wide illumination.
Here’s a comparison of the different optics I have, just quickly knocked up:
I’m a noob at doing comparisons here, so if anyone can tell me how to do a better demo I’d be happy to go back and make a new image.
I also ended up with a few spares of the wide optics, so I have a WTS thread. (I hope it’s OK to mention this here)
Apologies if this question has already been answered but I currently have a d4v2 in cool white XPL Hi V3
I am looking to buy a D4sv2 in cool white too but was not sure which LED and Tint to get?
Is there anywhere I can get some beamshots of XPL Hi / XPL HD / SST20
All in cool white 6500k
I am guessing the natural upgrade if I am a fan of cool white would be to get the XPL HD as this will give me 5300 lumens at max? whereas my d4v2 is on xpl hi so therefore giving me 4300L max
Hey what Hank light should I get next? I have the D4SV2 /6500k and the KR4/2000K. Thinking of the D18 but can’t decide what LED and optics. Torn between 2700, 4000, or deep red.
Thanks for the advice! Why do you think 4000 would be the best to get?
I talked to a guy another thread who suggested I get a tint mix.
“You could get a D18 with an even mix of SST-20 2700K and SST-20 4000K if you email Hank and ask. It would be around 3100K-3300K and below BBL.”
I suggested 4000k because you have a 6500k and 2000k emisar/noctigon light already, i love my sst20 4000k fw3a (its a great tint), i think the red sst20dr would get “old” (i want a sst20dr from hank as well, but will probably get it in d4sv2 to save :money_mouth_face:, and i would get the throw optics with the 4000k becuase itd be cool and unique to have a throwy flooder with awesome tint 4000k sst20’s. I have been wanting a d18 for awhile now and will probably get the 4000k variant. I just see the d18 as a utility/useful light, which i see needing a useful emitter, and i feel the 4000k is a sweet spot for nice light and useful brightness. imo
EDIT - of course my recommendations is from a position of someone who does NOT have any sub 4000k lights, so take that for what you will…
Can somebody hellp me. After month I cant get in utility mode anymore normaly? Everything else is working fine but from off 3 clicks or 2 clicks hold just exits the off mode and I have to click one more to turn light on. Try reseting few times same thing (dont have the tools to flash it)
I manage to enter sometimes after maxing the light lvl then turning off on for like 10 minutes doing crazy combos, but this is not solution and even when I enter its somewhat broken not blinkin right and cant set temp. Any fix for this?
Wow you’ve convinced me I’m going to order a 4000 and as you said, can always get another (:
I do love the 2000K. I’m sitting on the couch right now reason a book and that soft yellow light is so relaxing. In fact I’d love to get a D18 in 2000 and must keep it as a portable house lamp
