New Fireflylite T9R STB90.2 / Osram 1x21700 Thrower Preview
141 posts / 0 new
FireFlies
Last seen: 3 days 21 hours ago
Specifications:
• 1* Luminous STB90.2 or 1* Osram KW CULNM1
• Max output 4800-lumen or 1500-lumen
• Light Intensity: STB90.2 (400Kcd) ; Osram KW CULNM1 (680Kcd)
• Battery type 1×21700 / 18650 (65mm to 77mm)
• Built-in USB Type-C 2A fast charging
• Most efficiency 6A Constant current regulated Buck driver , Efficiency > 90% ;
• Made of 6063-T6 aluminum, Type III hard coat anodizing
• Ultra Clear AR Coating Glass lens
• Stainless steel side switch with built-in battery charging indication
• Waterproof: IP67
• UI – open-source Anduril firmware
• Size: 6.57’‘ x 2.51’‘ x 1.04’‘ / 167*64*26.5mm
• Netweight: 199 gram / 7.02 oz
Edited by: FireFlies on 09/28/2020 - 05:00
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 3 days 22 hours ago
Thanks a lot for showing another new interesting FireFlies light. Some questions...
  • It is advertised with Osram's Boost HX KW CULNM1.TG with 1,500lm using a 6A CC driver. If I am not mistaken the NM1.TG version is the 1mm² version with only about 900lm max. output. It's sweet spot in applied current is probably somewhere in between 3.8 and 4.8A. So, is it possible that you are using Osram's Boost HX KW CULPM1.TG with a 2mm² die area? That one would indeed match those numbers you advertise.
  • What's the maximum current on the SBT90.2 version? 6A constant current is nice for a decent brightness regulation on medium modes but for turbo this LED takes more than 18A to make it to 5,500lm. Most flashlights using the SBT90.2 seem to have an FET + DD (direct drive) or a CC (constant current) + DD (direct drive) circuit.
  • Last but not least...what's the price on these two lights? Smile
id30209
id30209's picture
Last seen: 2 hours 13 min ago
Love this design!
In.
WTB Titanium 4sevens 2xAA tube
SKV89
Last seen: 6 days 3 hours ago
USB-C recharge, much smaller size relative to the competition with same performance, nicely focused beam with no artifacts, and most important of all it’s the first time I’ve seen BUCK-BOOST DRIVER in these hot-rods!!!! Thumbs Up LOL
Can we have 8-10A max regulation with FET for the SBT90.2?
6A max would be good for CULNM1.TG and 8A max would be good for CULPM1.TG
id30209
id30209's picture
Oh yes i agree with SKV89, 10A regulated + FET would be perfect for SBT90.2
Anthon
Last seen: 4 days 3 hours ago
Very interesting
Glenn7
Last seen: 5 days 7 hours ago
When will these be available?
hasddie293
hasddie293's picture
Last seen: 7 months 1 day ago
I read multiple times the part it say “Most efficiency 6A Constant current regulated Buck/Boost driver , Efficiency > 90% “ is this kind of a new driver that I have not yet known? Who the technical guy here ?
In search of the most ideal flashlight in town:
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
Majoroverkill
Majoroverkill's picture
Well that’s just GREAT! Another torch I have to add to my list, THANKS! I do like the look of this new Fireflies torch. Looks like a nice deep reflector with a head around the size of the FT03! the Osram should be great in this but like most SBT90.2 lights this size its probably going to heat up fairly quick. Now if you could make it in the same color as your diagram that would be AWESOME! Silly Looking forward to seeing more of the T9R Thumbs Up
Doug S.
0oklight
0oklight's picture
Last seen: 4 weeks 1 hour ago
Well there goes my plan to mod my Weltool T11 with an SBT90.2!
I like the look of both these lights and no doubt will purchase. Interested to see how the constant current drivers play out in output and run times. I agree with others that at least for the SBT90.2 a FET would be a valuable addition.
EmptyWallets
Last seen: 1 month 1 week ago
The SBT90.2 version definitely has FET since they’re claiming 4800lm
refer to this testing:
http://budgetlightforum.com/node/71340
@6A it’s only doing ~2400 lumens
JaredM
JaredM's picture
Last seen: 4 hours 49 min ago
Definitely some numbers here that don’t add up, but looking forward to see more of this. Looks really nice in some aspects. Osram PM1 seems a good fit. SBT90 is just a bit too much for this format imo, but there’ve been worse applications. Too bad there isn’t something in the ~6mm² class with competitive surface brightness.. here’s for hoping an SBT70.2 comes about.
Th558
Th558's picture
Last seen: 27 min 5 sec ago
Seems nice. But why is it called Fireflylite? Don’t tell me they’re changing their name to that. Facepalm
will34
will34's picture
Last seen: 5 hours 29 min ago
Nice design, reminds me of a lemax. 6A appears to be too high for a NM1 and too low for a PM1…
SKV89
6A should be good for a BoostHL though maybe 5.5A is probably best. Remember this is a CULNM1.tg not CSLNM1.tg.
I think SBT90.2 is great in this host. You don’t have to run it on turbo. If it is run on 6A, the SBT90.2 will be super efficient and can stay cool probably indefinitely. But I think maybe 8A-10A max regulation would be best for added flexibility. But regardless, this is the best SBT90.2 host/driver I’ve seen in the mid/small size range. Mega performance and buck-boost driver in a small package (relative to its throw specs).
Tubercle
Last seen: 15 hours 38 min ago
Yes yes! Welcome back Fireflies with a new light! I was checking on your website last few months for signs of a new light!
As w/ others have said, I think 6A is too low for SBT90.2? Do love the USB-C charging tho, and host looks like its got good cooling properties.
ch1ir
Last seen: 22 hours 31 min ago
Love it
Emisar D⁴, Astrolux C8, BLF A6, Sofirn sp36aV2, Reylight Mini Pineapple, BLF 348 KillZone, Lumintop IYP07, Emisar D18, Boruit D10, Manker e01, Ultrafire z1, Massdrop titanium AAA, Astrolux HL01, Armytek Wizard Pro Nichia, Tacklife LFL3A, Astrolux FT03, Zanflair T1
lightdecay
Last seen: 8 months 3 weeks ago
The old name Fireflies was better, Fireflylite is not as good.
This is amazing:
• Most efficiency 6A Constant current regulated Buck/Boost driver , Efficiency > 90%
It is great to see more flashlights with efficient buck/boost drivers!
Could you also offer SBT-90 RED as an option? It has a low forward voltage, and it would really benefit from the buck/boost driver.
PBWilson
Last seen: 1 day 11 hours ago
I’ve been scratching my chin over a small, but super powerful thrower with this emitter when I saw the Lumintop one and the one from Amutorch. I can’t wait to see a head to head in the future. This one has a pretty cool look to it. Their designers crafted a great looking light!
Taskulamppu
Taskulamppu's picture
Last seen: 3 weeks 5 days ago
Noctigon K1 used to cost $80 but now it costs $90…
If this flashlight costs $60 – $70, it will make the K1 completely obsolete IMO.
Is there any ETA for release or info about pricing?
SKV89
I doubt this will cost less than the K1 if it uses buck-boost driver.
Tom E
Tom E's picture
Last seen: 8 hours 11 min ago
Can't compete with the larger K1 - a 64 mm diam. head is smaller than the 72 mm K1.
I'm getting over 500 kcd on my K1 SBT90.2.
thefreeman
thefreeman's picture
Last seen: 1 hour 43 min ago
Am I missing something about the boost part ? I only see buck being mentioned in the OP.
blueb8llz
Last seen: 4 hours 43 min ago
Any idea of the preorder or release date?
SKV89
I thought it was buck boost. Turned out it’s buck only.
Hardusvd70
Hardusvd70's picture
Last seen: 5 hours 56 min ago
Yeah only buck. That is the info they gave me.
Hardusvd70
FireFlies
EST Around 10th Nov
blueb8llz
That’s around the corner but still quite a whiles a way. I’m really looking forward to this light, maybe I’ll purchase a k1 to keep me entertained for the time being.
badtziscool
Last seen: 1 week 4 days ago
This is interesting. I have to ask though. With SBT-90.2 and Anduril, will this light exhibit the premature throttling of the output like on the Astrolux FT03S?
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 18 hours 36 min ago
Considering I haven’t heard of it occurring on the K1 w/SBT90.2 that probably comes down to component placement/overall design and potentially also having a proper firmware version that is calibrated for that version of the light – something Hank has for every light AFAIK, and which Fireflies may have for some of their newer models.
Hardusvd70
FireFlies wrote:
EST Around 10th Nov
Is the release date still around the 10th?
Hardusvd70
