Olight does make some good drivers which is one of the reasons I like Olight despite their shortcomings.
I have a hunch that this driver is an iteration of the one used in the S2R II which ZeroAir measured high to be ~500 lumens for 230 minutes on the 3200mAh. Using a 3500mAh will bring it to around ~250 minutes which is ahead of the warrior mini @530 lumens for 200 minutes.
Need some runtimes for the 15 lumen mode though. The WM is rated to last 50% longer than the S2R II @150h vs 100h
Yes sir, one of Olight staff anounced M1R is showing up in few months after one guy was constantly harrasing them (Olight admins) about it.
That fellow even created a poll to vote for M1R interrest where all Olight admins voted YES...
Like i said, maybe premature announcement so they had to remove that post.
That’s fair enough aha. I can’t speak for anyone else but I only buy Olights to mod as I really like their efficiency and while I don’t like their UI, they are easier to mod than Zebralight, and priced ok during sales with above average build quality.
Something about high efficiency really does it for me + I can get control the tint or CRI I want via modding.
still considering choices for the S2R, I am suspecting the high VF of a shaved LH351d might be detrimental to what I think is the buck driver in the S2R.
I have the 20 degree optic and I really like the beam profile. It’s similar to the stock optic in that it’s just one large hotspot but instead of a sharp cut off, it just bleeds into the spill nicely.
Thank you very much for the review! And that let me know I really need to get one of these!
Good specs, good UI, poor clip position, but that won’t stop me!
Thanks for the input
I quite like the Warrior Mini. It's tiny, powerful and has all those shortcuts you want. I don't like the Press and Hold to go through the modes though..
Well, although clicking is more intuitive for me, press & hold is ok, specially because it doesn’t take ages to change modes. I have the M2R so I suspect it will not be too much different.
I really wanted a light I could use with instant turbo and strobe for night walks (and winter is coming…), but at the same time use the lowest modes if needed and without having to cycle through them endlessly…
That light has that, and in a “small” pack (if compared to the M2R or the Brinyte PT18 Oathkeeper, that also has similar features).
I have to check the best place to buy it and try to catch the current discount :money_mouth_face: Any clues?
Thanks for the review! I was waiting for the runtime graph. As usual, Olight doesn’t lie about its specs unlike how most other manufacturers do. The efficiency is mind boggling. It seems to be the smallest dual switch 18650 in existence. However, how’s the tint and color temperature? Judging from the 75m photo, it appears to be CW with very high duv but the 10cm pic disagrees. Do you have the Lucky Sun D80 SST-40 5000k? I wonder how it compares. I really like that one.
I guess this makes for a good host for those that can do emitter swaps.
Nice review.
I found one thing that’s most probably incorrect though - you say that the included battery cannot be charged outside the light. I happen to have the Baton Pro, which comes with the same battery, and I charged it yesterday in an Xtar charger.
