Samsung 30q and Sony vtc6 are actually both rated at 15 amp continuous. So they are pretty much equivalent to each other. No real difference there.
The driver uses a button instead of a spring on it so I’m guessing you would need a battery with a button top. Maybe an owner can comment on whether a flat top cell will work or not.
FT03-Mini does have a “button” for positive side, but based on my test, LG HG2, Sony VTC6 or even the recessed flat-top Samsung 30Q works properly (BG does have an option where they bundle the FT03-Mini with a regular flat-top Samsung 30Q).
I tried bumping the flashlight too with a flat-top Samsung 30Q inside, and the light did not “stutter” (no disconnection from bumping), so the tailspring does it job well.
Got my greenie. Guess I didn't read the fine print - didn't realize it's a UI all their own, not Anduril, no AUX LED's around the LED.
I measured 4.2 tail amps on a 35E at 4.06V, but on a VTC5D, measured 5.2 tail amps. So, what does this tell us? Is it a FET with limited amps or just poor regulation?
Don't think it's a problem for the green - think it can take higher amps than the white or red?
Would also like to know if the green does take higher amps than the white and red (as mentioned in another thread, the red didn’t seem to have visible brightness difference when on High or on Turbo mode), whereas the white one will turn a bit bluish on Turbo. The green looks a wee bit brighter from High going to Turbo, again as per the sample I got of the FT03-Mini Osram (white/green/red)
