[Available again! - BLF special edition light] new Sofirn AAA twisty high CRI 5mm LED
although I would also enjoy a wider beam option for things within arms reach
the existing narrow beam works well past arms reach
the C01S beam, and the C01R beam are almost the same (same optic different LED size).
from 4 feet away my C01R has a larger, more useful hotspot for me, than my Lumintop Copper Tool modded to 660nm:
Apologies if this has been stated before. I searched the thread and found info about lego-ing the original C01 with the Fenix E01. But has anyone tried to lego the C01 and the C01S? Or do we know for certain that the (new / upcoming) C01 and current C01S would go together?
If they do go together, I think I might order several so I can have different body tube colors. Has anyone tried?
yes, my C01, C01S and C01R all lego
Thanks! Now I hope that Barry’s teaser picture becomes a product before November so I can order a bunch for Christmas gifts.
I would like C01 host with modes bright,the low below 0.5lm
I hope nobody minds doubleposting here. I have also posted this in the C01R thread but one of these lights will have a 5mm LED, so it might be interesting here as well.
Barry was so kind to send me a quick whitewall-shot from his smartphone camera.
From left to right...
Sofirn C01 5mm 670nm (prototype)
Sofirn C01R SST20-DR 660nm (prototype)
Sofirn C01R XP-E2 PR 660nm (series version)
Comments based upon some feedback from Barry:
  • actual perception of deep red color is more intense than indicated here
  • C01R SST20-DR is quite similar in maximum brightness - although actual brightness may differ but needs to be measured using a lux meter
  • hotspot beam shape/profile of C01R SST20-DR is yet to be reviewed in detail as any artifacts cannot be assessed on that picture - for now it looks quite similar to XP-E2 PR
  • production of C01 using the 670nm 5mm emitter may be revoked as the beam shows significant distortions - final decision is not made yet
Yeah, that 5mm beam looks awful. I wonder if the old scotchbrite scruff treatment would help that artifact.
Yep, scotchbrite do the trick. I’m ising it always on my 5mm setups
Oofa… I’ve seen car tail lights better than that 5mm.
Thoughts on the poor beam pattern of the 5mm Red…
After using the C01R for a couple of weeks, I understand what many others have mentioned: with completely dark-adjusted eyes, the Low of the C01R is still quite bright. The High seems like it could do some serious damage with fully wide open pupils.
Since Sofirn has committed to another batch of the (relatively) high-powered C01R, I wonder if they’d consider salvaging the 5mm Red as a one-mode sub-lumen light and include a diffuser with each. Then, the beam pattern wouldn’t matter at all - even more so if they can find a pebbled optic, too. With this kind of change the C01 5mm Red and C01R wouldn’t compete with each other for sales, either. The niche here is not as a novelty toy, but seriously targeting the astrophotography groups that want an extremely low light that won’t singe your eyeballs if you accidentally look directly at it.
If still counting, I’m in for a 3400k
I am not interested in a 5mm Red C01
I am most interested in another run like the original High CRI C01.
I am very happy with the xp-e2 660nm C01R, I would do it again
dont know what SST does better than 660nm, but open to either option.
I agree the C01R has higher brightness than I need, and I would be fine with lowering all 3 modes
Our latest product C01, using Sophia lamp beads, 3400K CRI 95+ 5mm LED. We have prepared 5000pcs emitter, expected to arrive at next week , Black, Blue, Orange, Green, Desert Tan each color 1K. In addition, there are 1K red , using 670nm red emitter.
AWESOME!!
Just in time for Christmas.
Thank you. We all have been waiting for this a long time.
But the other question: will you sell a portion of these lights without a led?
So people can experiment with a led of their own choice, like a UV-led?
we don’t sell C01 lights without led, but you can buy it and replace led yourself.
Good news, thank you! :+1:
Not so good news :weary: .
Can we get these on Amazon Canada?
Hurray for more C01!
I’d probably order more if there were a host available, but as is, I still need at least a couple to swap 2300K’s into.
