I have a few L21a’s
One it the first batch, which does not allow larger 21700 cells, the others a 2nd batch, which allows larger 21700’s
Simon Mao, I think you need a bit of help here. If you want your flashlights to satisfy all your customers, you must bear in mind your flashlights need to fit the entire range of available cells they are supposed to fit.
You just cannot presume your customers are going to use “only this or that battery”, this is wrong my dear. In one way or another many of your customers are buying cells from reputable chinese OEMs like Far East Battery (example), or Lishen. Once rewrapped by 3rd parties the cells from these manufacturers measure up to ∅21.7mm. Play it safe, add an extra 0.5% or 1% to that figure and make sure the 21700 tubes of your flashlights are bored (drilled) to at least ∅21.8mm or ∅21.9mm. If your flashlights can accept all sorts of 21700 cells everyone will be satisfied, diameter or tube bore is paramount in this regard.
uh ,inner diameter has been changed to 22mm ,It’s just that some styles sell slowly, it is still the first batch, the inner diameter is still 21.5mm
… uh ,inner diameter has been changed to 22mm ,It’s just that some styles sell slowly, it is still the first batch, the inner diameter is still 21.5mm
Wise decision. :THUMBS-UP:
Hello Simon.
Please advise if you are planing to update L6 or L21A using SBT90 diode and what price will be for both? I think many people will buy L6 with SBT90 for reasonable price 70-80 USD or L21A for 60-65 USD.
Barkuti:Simon Mao, I think you need a bit of help here. If you want your flashlights to satisfy all your customers, you must bear in mind your flashlights need to fit the entire range of available cells they are supposed to fit.
What about length of the tube?
With new driver spring, length should be 4mm longer.
Otherwise springs does not work like springs.
Hello Simon.
i’m ready to use 4X18A or 3X21700 host to install SBT90.2
Exciting!!^^^^^
4x18A and SBT90.2…
I want one.
Looking forward to this. Should hit around 370kcd if driven hard.
iRattle:Hello Simon. Please advise if you are planing to update L6 or L21A using SBT90 diode and what price will be for both? I think many people will buy L6 with SBT90 for reasonable price 70-80 USD or L21A for 60-65 USD.
Please, 3 x 21700 using flat top batteries. 21700 cells will get more attention in terms of developing high drain cells.
Please advise if you are planing to update L6 or L21A using SBT90 diode and what price will be for both? I think many people will buy L6 with SBT90 for reasonable price 70-80 USD or L21A for 60-65 USD.i’m ready to use 4X18A or 3X21700 host to install SBT90.2
3X21700 host will be great.
Simon Mao: iRattle:Hello Simon.
+1
Um…btw, I just posted the Z1 review, so you can check it
Convoy Z1 - Convoy's first zoom flashlight (well, it was clickbait, actually the second one) 3 in 1 review. At the end there will be a summary for those who like only particulars, in each topic I will bold the key sentences for those who read a little more, and a long waffling for everyone else. Enjoy! [image] For VERY large photos: click -> on the photo page right click -> "Open image in new tab" Table of Contents: -General parameters - Package content - Appearance, parameters …
The only issue with using flat top cells in a 3x21700 light is that inherently those designs have a “ring” for the driver (see: SP36, Q8, MS06 etc) - it’d need an adapter like the one in the 4x18A with brass slugs to work. I’m all for that though! (I still want to buy that adapter by itself……)
Dont worry ,i have adapter for 3*21700, too
<3
High drain cells won’t be necessary with a single 90.2 in this light. Turbo would only be about a 2C discharge rate
oweban:The only issue with using flat top cells in a 3x21700 light is that inherently those designs have a “ring” for the driver (see: SP36, Q8, MS06 etc) - it’d need an adapter like the one in the 4x18A with brass slugs to work. I’m all for that though! (I still want to buy that adapter by itself……)
Thank you, the idea of some triple 21700’s is encouraging. A Convoy 4X18A or 3X21A flashlight gives a few great LED options like Luminus SBT-90 or triples.
oweban:The only issue with using flat top cells in a 3x21700 light is that inherently those designs have a “ring” for the driver (see: SP36, Q8, MS06 etc) - it’d need an adapter like the one in the 4x18A with brass slugs to work. I’m all for that though! (I still want to buy that adapter by itself…)
Awesome! There are only few 21700 button top cells on the market, mostly proprietary batteries with a PCB from Imalent, Klarus, Acebeam etc.. These batteries are very expensive, though. So, let's please stick with support for standard 21700 cells that are flat top or even with a recessed top (see "Tesla" batteries sold by Vapcell). Thanks for the great work, Simon!
Just received S21B W2.1 I’m impressed!!
PS S2+ clips fits erfect on S21 family...0
PS S2+ clips fits erfect on S21 family…0
Looks really nice. Apart from the design of the 2, is there any difference in beam profile?
