Sofirn SC31 PRO, New Anduril Flashlight
360 posts / 0 new
TimMc
TimMc's picture
Last seen: 1 hour 51 min ago
Nachtfeuerzeug wrote:
I think you can do that with a 500 mA USB power source. Don’t use a quick charger. You might have an older phone charger sitting
around.
I tried charging a KeepPower IMR18350 in the SC31 Pro.
Discharged to 2.8V.
Setup:
- Wall wart with USB-A socket providing 5V 2.4A output
- USB-A to USB-C cable connecting wall wart to USB-C input of the USB Tester
- RD UM25C USB Tester with USB-A to USB-C cable connecting to the USB-C input of the SC31 Pro
5V 1.17A initially when around 2.8V
5V 1.09A when around 3.2V
When I switched to USB3 output from a laptop, it dropped to 5V 0.86A.
It’s probably not the best way to test…
KP 18350 1200mAh has a 1.1A max charge. 1.17A is a bit on the high side.
EDIT:
Quote:
Minimum Capacity: 1100 mAh
Typical Capacity: 1150 mAh
Nominal Voltage: 3.7V
Charging Voltage: 4.20V
Standard Charging Current: 0.22A
Max Charging Current: 1.1A
Discharge End Voltage: 2.5V
Max. Continuous Discharging Current: 10A
Max. Pulse Discharging Current: 15A
https://www.illumn.com/18350-keeppower-imr18350-1200mah-high-discharge-f...
https://www.keeppower.com.cn/products_detail.php?id=567
I later charged it with an XTAR VP2 to 4V and then inserted the 18350 into SC31 Pro to charge it more. 300-500mA charge rate. It terminated at 4.16V. I put it back in the XTAR VP2 to get it to 4.19V.
d_t_a
Last seen: 1 hour 42 min ago
around.
Discharged to 2.8V.
Setup:
EDIT:
I suppose this is one scenario wherein a lower-rating (older) USB power adapter will be useful..
In general, I often shelve aside lower-current (older) USB power adapters since I want to charge my USB devices with at least 1 Amp or higher.
I have a related question: I have some “poor quality” USB cables that pass very low current, eg. even if I use a 5v/2.4A USB power adapter, it will only charge at 0.5A or lower, compared to when I use a good quality USB cable. Will using a “low-quality” cable to limit the charging current be safe to use?
TimMc
TimMc's picture
Not sure. I found an interesting blog post about this:
https://goughlui.com/2014/10/01/usb-cable-resistance-why-your-phonetable...
Nachtfeuerzeug
Nachtfeuerzeug's picture
Last seen: 2 months 8 hours ago
Well, that explains my observations. I'm glad I have one of those cable testers.
EDC
FW3A, SST20 4000K || S21A, Crescendo Mtn20DD, LH351D 4000K || SP32A, SST40 5000K
Recent/ongoing Mods:
S2+, TexAven 17mm, LH351D | S21A, Crescendo 20mm, XPL HI 5000K | L2 w/Mtn17DD Zener Guppydrv, XHP-50 | C8+ OP, DD XHP-50
SP32A w/SST40 5000K | TIR Upgrades | EagleTac clip | Ultrafire C2 w/6A 20mm & LH351D | S2+, Biscotti, Nichia 219C 2700K |
Reviews:
Sofirn SP31 v2.0 Tactical Flashlight (Cree XPL HI) || Sofirn SD05 Scuba Diving Flashlight || Sofirn SC31 USB Rechargeable (XP-G3) || Sofirn SC31 Pro 5000K
Funtastic
Funtastic's picture
Last seen: 51 min 22 sec ago
Where’s the best place to buy D-C Fix?
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
pennzy
pennzy's picture
Last seen: 8 min 20 sec ago
How much do you want? Boaz sells small quantities or Amazon if you need more. The milky is the original.
Funtastic
Funtastic's picture
Thank you
Just wish it wasn’t going to cost the same amount in shipping for New Zealand
stephenk
stephenk's picture
Last seen: 2 hours 59 min ago
Funtastic wrote:
Thank you
Still worth the purchase though!
TimMc
TimMc's picture
SC31 Pro with DC-Fix from Boaz:
Video of SC31 Pro 5000K going from Turbo to low with DC-Fix:
https://i.imgur.com/mwD14jH.mp4
Lightbringer
Lightbringer's picture
Last seen: 2 hours 18 min ago
Yeh, I’m leaving my ‘pro as-is, but most of my other lights that aren’t dedicated throwers (GTmicro, etc.) all get “fixed”.
Even the big Tacklife I got has a G3 with all its hideous tint-shift, but is nicely throwy… if you want that. Makes a great around-the-house light with diffusion film in front, a nice smooth blanket of light, and no shift.
The ‘pro doesn’t really need it, but it can certainly come in handy.
d_t_a
I’m wondering if the SC31 Pro ordered from Sofirn AliExpress includes 2 tailcaps (1 nonmagnetic + 1 magnetic)?
I’ve ordered the SC31 Pro 5000k tint from there, but the shipping is taking quite long, so am curious if it will come with both tailcaps or just 1 tailcap (if 1 tailcap, is it the nonmagnetic or the magnetic one)?
I had previously ordered the SC31 Pro 6500k from another Sofirn site earlier (when the 5000k was not yet released), and that set came with 2 tailcaps, was curious if the set from Sofirn AliExpress will also include both tailcaps..
Grumsel
Last seen: 18 hours 33 min ago
I ordered 2 SC31 Pros from AliExpress and both came with only 1 tailcap, a nonmagnetic one.
TimMc
TimMc's picture
I ordered the SC31 Pro 5000K from AE during that sale with a $5 coupon..
It came with a regular tail cap.
I also ordered an 18350 tube, magnetic tail cap and some emitters from the sofirnlight website. These arrived a week before the AE order.
I prefer the regular tail cap. It’s slightly shorter and I don’t need to worry about a strong magnet in my pocket interfering with other electronics.
Sillen
Sillen's picture
Last seen: 5 days 2 hours ago
Yes, sofirnlight.com much faster shipping. 3 orders average 10 days delivery to Melbourne. AE 20-30 days minimum.
Ordered SC31 Pro a few days before special offer so paid for my mag tail Sad Like u still unattached
BLF-L
BLF-L's picture
Last seen: 3 days 5 min ago
Me too, I’m curious.
I ordered two SC31PROs (5000K) from sofirn AliExpress.
I requested magnetic tailcaps as bonus. Don’t know whether they would actually give the bonus tailcaps or not. If they come with those extra tailcaps I’ll be very happy, if not then so be it, as long as the package is actually delivered.
Quote:
… but the shipping is taking quite long …
Yup, it’s been so looooong , I ordered on August 25th, it’s said shipped on September 4th. But the tracking shows the package doesn’t seem to move at all.
My order from Convoy AliExpress didn’t take that long.
I got the idea of requesting bonus tailcaps (magnetic) from a YouTube video reviewing SC31PRO , the video description mentioned about bonus tailcaps, not from AliExpress sofirn store though.
d_t_a
In my case, Sofirnlight.com takes a LOT longer. Ordered several flashlights last May, divided into 2 shipments. First package arrived last September, still waiting for the second package to arrive.
Ordered from Sofirn/AE, used a different shipping option (pre-Covid, the Sofirn/AliExpress used a fast shipping method via Singapore Post, which arrives in about 2-3 weeks, I considered that ‘very fast’ for a free shipping option). But now post-Covid, Sofirn/AE used a different shipping method (untracked — can track only while in China, but no tracking updated anymore when it reaches our country) and it seems to take longer. Ordered August 27, package not yet arrived.. although based on tracking, it has reached our country..
maba
Last seen: 3 days 22 hours ago
Big Smile
Optiblue
Man would love to see this light come in 4000-4500K range.
Don't keep blue bin emitters alive during the golden age of neutral white!
degman
degman's picture
Last seen: 1 day 17 hours ago
SST40 not have less than 5000k. Have to change diode for this tint. Maybe SST20, Samsung or Nichia. But Lumens will be lower.
Optiblue
Yeah it’s tough trading lumens for tint! If swapping out for the SST20, the SC31B would have it. If swapping for Samsung, it would essentially become the FC11 xD Being picky with tints is a curse, but 4000K looks so good Sad
Cemoi
Last seen: 1 week 5 days ago
Thanks all for your reviews and information.
@Sofirn: I will wait for a High CRI version to be available (Nichia E21A?).
Ultrafire C3 2AA / Akoray K-106 / Nitecore LR10 / Manker E03H / Fenix HL10 / Zebralight H501R + H51W + H53c / DQG Hobi / Astrolux M01 / CooYoo Quantum Ti (lost) / BlackWater Kite Al / Emisar D4v2 (Nichia E21A) / Sofirn C01S / Skilhunt E3A
Tom E
Tom E's picture
Last seen: 12 hours 23 min ago
The XPL HI V2 5D is a great compromise between output and tint - nice mild rosy tint, decent output. Still one of, if not most favorite. Not high CRI though.
BLF-L
BLF-L's picture
Tom E wrote:
The XPL HI V2 5D is a great compromise between output and tint – nice mild rosy tint, decent output. Still one of, if not most favorite. Not high CRI though.
Hi Tom, is XPL HI V2 5D better than T6 4C?
More output? What’s the CCT number?
What about the CRI number?
Currently my favorite is T6 4C (Convoy S2+), it’s mentioned as 4300-4500K.
What flashlight is available with V2 5D?
Tom E
Tom E's picture
Dunno what a CCT # is, and dunno the CRI - not sure if it's rated or not, but it's on the low side. Used to get them from Hank, but now I don't see them listed anymore, but still available in some Emisars. MtnE still has some remaining stock.
Interesting bout the 4C - the 'C' means above the BBL while the 4A, 4D and 5D are below BBL (https://flashlightwiki.com/images/c/cb/Ansi-white.jpg)
They have more output than then 95+ CRI SST-20's for sure. The 5D puts it at 4000K or lower.
Nachtfeuerzeug
I took some beam shots this weekend that could be informative related to you all's recent comments. I should be able to post this evening.
EDC
Reviews:
jp9mm
Last seen: 3 weeks 3 days ago
I took some beam shots this weekend that could be informative related to you all’s recent comments. I should be able to post this evening.
So what 4k emitter did you swap in? Innocent
Nachtfeuerzeug
So what 4k emitter did you swap in? O:)
Funny you would ask. Lol
The way I read Tom's message is as a suggestion to use an emitter that can handle the output of this driver. And produce an arbitrary >1500 lumens. So, an XP-L HI, SST40, LH351D, XHP 50 3V, etc. would befit this light.
I've installed an LH351D, 4000K, in an older SP32A (see my signature box) but I prefer the beam of an SST40.
EDC
Reviews:
Nachtfeuerzeug
Here are the beam shots I mentioned earlier: http://budgetlightforum.com/comment/1705089#comment-1705089
In addition to those, I did capture one with the SC31 Pro 6500K (next to a S21A 5000K)
EDC
Reviews:
Optiblue
The top photo is the 6500K of the sc31 pro and bottom is the convoy? Dang the convoy punches harder and goes further. Looks fantastic!
Barry0892
Barry0892's picture
Last seen: 5 hours 15 min ago
Anyone compare SC31 Pro 5000K with 6500K? I believe the tint is not much different. Because 6500K tint is actually 6000K - 6500K
SC31Pro KIT (Get magnetic tail for FREE)
WhatsApp: +8615773183209
My new Facebook account: https://www.facebook.com/barry.dong.9250
