Fair enough. My gut is around 680 here. But the calcs I was doing were coming out a good bit lower. When we’re dealing with big numbers like these, a +/-10% error is huge.
Ooops, missed the pic. I see couple issues with the battery choices though: Ouch: 2 different kinds of cells used? Flat tops - gotta wonder how good the contact is, hope all 3 cells are contacting for best amps.
Looks like the cells are in tight, so wondering if that's the best minimum width or are the walls of the tube thicker than a Q8. Awesome wall of light in the beamshots - Yes!
Hello,
Is there an option to blinkout the Anduril Version?
I think, if it´s Anduril, it´s Anduril 1.
Has Toykeeper one page with the differences listed between the Anduril versions?
Thanks.
I have not been able to figure out how to attach pictures here, either. I do not use online image hosts. I attach my pictures on another forum, where I pay one cent per hour to not have to deal with image host sites. I am glad that you got your HK 90. I ordered my HK 90 from Banggood group buy on September 7, but it has not shipped yet.
You really can't overdrive 3 SBT90.2's on 3 40T's, or 30T's for that matter, regardless of FET and thick wires used.
My GT kit upgraded to a GT90 is probably about 30 amps for just one LED, but that's an incredible 8P battery setup.
Would be nice to have a 6 cell battery tube option for this light, but that would require GT style carriers.
I've de-windowed a few GT90.2's. Could expect a 5%, maybe up to 10% boost. Side by side, I can't see any difference in the beam tints but that could be me - 62 year old eyes
I'd probably do the dirty de-window deed on the HK90.
1lumen has their review up. Looks like 688kcd at startup and dropping like a rock. I didn’t see a 30sec value posted but the output graphs would suggest it comes in around the mode 7/7 value of 234kcd. If thermal config were adjusted I’m sure this would sustain more, but three 90.2s in a handheld is silliness to begin with. For the sustained output and throw this light can achieve, it really makes little sense to me. A K65 w/ 70.2 will do the same (sustained) numbers in a smaller package.
To me it looks like temp calibration wasn't done, or done properly. Yes, there's a lot of heat but it's a pretty big light, lots of metal. If I can get 30 amps out of a tiny Amutorch X9 w/triple XHP50.2 3V's, certainly 60 amps in the much much larger HK90 is do-able, and can run 30 seconds without scorching fingers.
It’s obvious that the calibration or tuning is way off. I’d expect it to sustain 7-8k lumens without fan cooling if it’s allowed 65C. It should definitely be able to keep above the 10k mark for 30-60 sec.
