Mostly just regular use tends to keep the switches working well, I did have to do some repairs when a few of them came and replaced some of the corroded brass and copper parts with pure silver sheet metal cut to shape, and of course liberal use of switch cleaner and elbow grease, but once they`re up and running, regular use keeps them in good working order.
Do you use Deoxit? I squirted some of the wrong type of a cheaper switch cleaner into one of my maglite switches and ended up having to tear it apart and clean it out with isoprop. Works flawlessly now though.
“Do you still own any non LED powered lights?”
yes.
for the reason Katherine already posted.
i am 9 years old again reading a book….
just not a comic book under the covers.
yea, i have several stock maglites, 2d 4d. and 1aa. surefire g3 mag 85, 200w hotwire mag. and several cheap 2d flashlights with bulbs that i keep as loaners, thou i do not use any of them on regular basis,
Nope. The last incan I owned (a Duracell Durabeam, 2AA side by side) died a loooong time ago. I don’t believe I so much as touched an incan torch in the last 15 years at least, it’s all been LED for me. Moreso now with the warm white options in the market.
That stuff looks very good. I was always put off by the price of Deoxit. I ended up buying some other cheap stuff, Kontakt PR, and squirted some into one of my Mag C switches. Made it even worse. Had to strip down the switch completely and clean it with meths.
you have my sympathies, I had to strip down a Mag D switch assembly because an alkaleak ate away almost the entire + contact right into the assembly itself, they`re not the easiest things to understand when you first open them
I made a new contact out of sheet silver and it`s all good again, but it wasn`t the Most fun I`v had repairing a light! LOL
Leading cause of death for old Maglites, the alkaleak. Aluminium + caustic potash is always such an enthusiastic reaction.
I have an itch to build another hotwire Mag. My 5761 3C mod is already starting to feel a little anaemic, and my pal has promised me his old 3D he’s not using, once he gets around to finding it. But just how much juice can a standard Mag switch stand before it starts getting all melty and burny inside?
That`s a really good question actually and I have no idea to be honest what it`s rated at, But with it being a fairly low voltage and a non-inductive load then contact arcing shouldn`t be much of an issue, having looked at the insides of a D assembly I would say no more than about 5A constant. I`d like to be wrong though because 5A wont really buy you much without cranking up the voltage.
The Philips 5761 is rated at 30W for 6V, and seems happy enough at 7.2-8.1V, so I guess we’re looking at around 4A in that case?
I’m thinking my next mod would involve a fivemega 6.35 ceramic socket with a 100W Osram HLX64623 running at 12V. That’s a whole lot more amps, but removing the plastic tower would leave room to put a mosfet in there.
And just to be extra silly, if I could find a suitable aspheric to put on the front…?
You’re right. 5A is what Mag switch can take it unless you modify to momentary only and add Jimmy’s PhD on top of the switch with removed tower...and with FM 6.35 Brass socket...
Oh god, can’t wait to get home and light it up.
i owe this thread photos and build notes...
I think having one around is good for reference purposes. I bought a 7.2v Xenon UltraFire WF-502B (and an extra 3.7v Xenon drop-in) ten or more years ago and I still keep it just in case I want to see what 100 CRI looks like.
Pretty useless as a torch with a small hotspot with not much spill, and being too demanding on low drain cells.
I still have a Streamlight Stinger from 2007? Maybe sooner. It was my first ‘serious’ flashlight and was as bright as a 4D Mag and a lot smaller. Really popular with police officers. It still works awesome, just need to get new battery packs.
I have two Victorian oil lamps, one is modern (late 1990’s), the other belonged to my Great Grandmother and dates back to the early 20th century (still works).
