I can’t be sure without having one to test but what looks like a black 603 resistor just to the left of the numbers 200506 might be a thermistor.
I see they have moved components on the left side up a little to make room for two extra components.
thanks for your great observations and info
so, a thermistor does what? dims the light at a certain temperature?
I also see other changes, no idea what it all means
btw, I received the 2020 driver from Jchang76 as a free upgrade, after I lent him a 2019 driver… I am very grateful to have the option to test the newest driver… Thank you!
Its a resistor that changes value with temperature. You can read about it here.
It could be using a thermistor and a resistor (the two foghorne circled) to create a voltage divider like described in section “Hardware linearization solution”.
Its missing from the battery side of the board. It could be that it was relocated on the other side of the battery pcb, which we dont have a view of.
Its a two piece stacked pcb driver.
moderator007, can you say from the changes you see in the components what the purpose may be? Would the design dim the light to maintain a max temperature or will it work as a safeguard to shut it off if a temperature is reached?
If it is a thermistor it only gives the mcu a way to measure the temp. The code that compares the reading would determine where and when step down or shut down would happen. It was all up to the designer and coder as to the features.
So there is a possiblity the hardware is there but the code to take advantage of it is not.
I did turn on 2 TC-R1 lights, one with the 2019 and one with the 2020 driver and put them side by side on the table until they got fairly hot, but I did not push it because I have had a 2019 driver die on my a few days after I used the light for an actual emergency where I had to repair my girlfriends home lights that shorted. so the light was on top of a wardrobe on max until the battery almost died, while I was repairing the lights. It got quite hot but kept working and as the battery was depleted, output and temperature were lower and the light cooled off and kept working. A few days later, the light would suddenly not turn on. Replacing the driver fixed it. It looks like temperature killed the driver but not on the spot. In any case I am since reluctant to repeat the experiment and was excited to hear the 2020 driver may have some kind of thermal regulation / protection, but my short trial did not show it has. Maybe it needs to be tested for longer.
I believe that those values are due to the different working of the drivers.
The one of the 2020 version is to be used along with a tailswitch closes the circuit energy, hence preventing the drain.
The 2012 and 2019 will probably act more like an e-switch that doesn’t completely shut down the energy circulation.
So, in my head, the 2020 driver version is probably projected differently than the ones of the previous versions, which are supposed to reduce the drain once the rotary ring acts as the switch itself.
Also in my head, it doesn’t seem to make much sense to use the 2020 version with the tailswitch ON and then only use the rotary ring.
It makes sense to dial a “level” through the rotary ring and then just turn the light ON/OFF, acting as a single mode light. Having a forward clicky switch is even better (for me), as it allows momentary on for the lowest modes without full clicking
and thank you for starting a wonderfully informative thread
My first reason to replace an RRT-01 driver, was because I destroyed one when disassembling the light incorrectly.
I have also intentionally upgraded from a 2012 driver to 2019 driver, in order to obtain the Strobe function
this is a good upgrade
the 2019 light also claims a 950 lumen output, whereas the 2012 driver claimed 600 lumens
that might lead some of us to hope that the 2019 driver will be brighter. Im not sure that is true, as I think the main difference is in the LED… but I dont have solid data
but here are the driver options I have seen Jetbeam use:
2011, no strobe, driver label says RRT-01
2012, no strobe, driver label says Eye10
2012, yes strobe, driver label says Eye10 (serial number on body is different format)
2019, yes strobe, driver label says Eye10
2020, yes strobe, driver label says Eye10
2020, yes strobe, unverified thermal protection, driver label says RRT-01
driver feature progression
original 20212 rrt-01, no strobe
2019 model, yes strobe, possible higher output
2020 model, yes strobe, plus claimed thermal protection
Thanks for reminding me Jon.
I still have a nib 2012 version that I want to mod into a more throwy light. 2700k sst-20, reflector mod and 2019 driver.
Time to order some parts.
