Is the small part circled in green diode D3?.
thanks for your great observations and info
so, a thermistor does what? dims the light at a certain temperature?
I also see other changes, no idea what it all means
btw, I received the 2020 driver from Jchang76 as a free upgrade, after I lent him a 2019 driver… I am very grateful to have the option to test the newest driver… Thank you!
I dont know, why do you ask?
D3 on the 2019 board is missing on the 2020 version.
Its a resistor that changes value with temperature.
You can read about it here.
It could be using a thermistor and a resistor (the two foghorne circled) to create a voltage divider like described in section “Hardware linearization solution”.
Its missing from the battery side of the board. It could be that it was relocated on the other side of the battery pcb, which we dont have a view of.
Its a two piece stacked pcb driver.
moderator007, can you say from the changes you see in the components what the purpose may be? Would the design dim the light to maintain a max temperature or will it work as a safeguard to shut it off if a temperature is reached?
If it is a thermistor it only gives the mcu a way to measure the temp. The code that compares the reading would determine where and when step down or shut down would happen. It was all up to the designer and coder as to the features.
So there is a possiblity the hardware is there but the code to take advantage of it is not.
I did turn on 2 TC-R1 lights, one with the 2019 and one with the 2020 driver and put them side by side on the table until they got fairly hot, but I did not push it because I have had a 2019 driver die on my a few days after I used the light for an actual emergency where I had to repair my girlfriends home lights that shorted. so the light was on top of a wardrobe on max until the battery almost died, while I was repairing the lights. It got quite hot but kept working and as the battery was depleted, output and temperature were lower and the light cooled off and kept working. A few days later, the light would suddenly not turn on. Replacing the driver fixed it. It looks like temperature killed the driver but not on the spot. In any case I am since reluctant to repeat the experiment and was excited to hear the 2020 driver may have some kind of thermal regulation / protection, but my short trial did not show it has. Maybe it needs to be tested for longer.
I would want an IR thermometer, to track temperature… or some fancy autologger like I see in some reviews
trust but verify
regarding the 2020 RRT-01:
what is the parasitic drain when the dial is turned to minimum?
the 2012 has a drain of 55uA (selbuilt)
the 2019 has a drain of 27uA (djozz)
the 2020 has a drain of ~28uA (pol77)
I believe that those values are due to the different working of the drivers.
The one of the 2020 version is to be used along with a tailswitch closes the circuit energy, hence preventing the drain.
The 2012 and 2019 will probably act more like an e-switch that doesn’t completely shut down the energy circulation.
So, in my head, the 2020 driver version is probably projected differently than the ones of the previous versions, which are supposed to reduce the drain once the rotary ring acts as the switch itself.
Also in my head, it doesn’t seem to make much sense to use the 2020 version with the tailswitch ON and then only use the rotary ring.
It makes sense to dial a “level” through the rotary ring and then just turn the light ON/OFF, acting as a single mode light. Having a forward clicky switch is even better (for me), as it allows momentary on for the lowest modes without full clicking
the question has come up repeatedly from people wanting to know if they can use the 2020 model on standby
edit
turns out, thanks to a test by pol77, that the standby drain on 2019 and 2020 RRT-01 is the same, I dont know if there is working thermal protection in the 2020 as claimed
Yup, looking at those values, it surely would be a downgrade as the originals would be more suitable for the lights than the “new” one.
I am not familiar with the new lights, I was only absorbing and reinforcing (althought without data) what you wrote before.
It really doesn’t make sense using the light that way nor modding other lights with a different driver, be it due the thermal sensor or not
Thanks for the explanation on this
and thank you for starting a wonderfully informative thread
My first reason to replace an RRT-01 driver, was because I destroyed one when disassembling the light incorrectly.
I have also intentionally upgraded from a 2012 driver to 2019 driver, in order to obtain the Strobe function
this is a good upgrade
the 2019 light also claims a 950 lumen output, whereas the 2012 driver claimed 600 lumens
that might lead some of us to hope that the 2019 driver will be brighter. Im not sure that is true, as I think the main difference is in the LED… but I dont have solid data
but here are the driver options I have seen Jetbeam use:
2011, no strobe, driver label says RRT-01
2012, no strobe, driver label says Eye10
2012, yes strobe, driver label says Eye10 (serial number on body is different format)
2019, yes strobe, driver label says Eye10
2020, yes strobe, driver label says Eye10
2020, yes strobe, unverified thermal protection, driver label says RRT-01
driver feature progression
original 20212 rrt-01, no strobe
2019 model, yes strobe, possible higher output
2020 model, yes strobe, plus claimed thermal protection
I just ordered a couple of spare 2019 RRT-01 drivers.
Where did you buy the drivers?
Here is the partslist for a 2012 RRT-01 mod
includes driver source, and reflector source thanks to moderator007
more discussion about the 2019 driver
eyecandy thanks to Geuzzz:
Thanks for reminding me Jon.
I still have a nib 2012 version that I want to mod into a more throwy light. 2700k sst-20, reflector mod and 2019 driver.
Time to order some parts.
your mods are an inspiration:
if you get a chance to offer the links to the lens and O ring you used, would be appreciated
a beamshot on a wall would be welcome too
The oring was just a fat +–20mm one out of my junk parts box. IIRC I used this ‘’convoy’’ lens:
https://nl.aliexpress.com/item/1577614278.html?spm=a2g0z.12010612.8148356.13.3c2f42e11mvX8y
How bad is this parasitic drain on the 2020? Is the driver pretty much the same besides that?
