Yea, usually light during the day while working on an install or searching for random things here and there under the car/ engine compartment/barn work shop/etc. and at night if iām hiking and the sun sets I would be more apt to hold the light in a normal position but turn it on/off in the reverse ācopā grip. I wish I was at the point of doing two hour runs, its been a really long time since Iāve been there (but thats on me) AND I had not even realized what your u/name was until nowā¦ I do agree with you, if you are running then headlamp all the way, definitely not carrying a torch. Im not here to disagree or push a light on you, just having some fun. Keep it light out there. -Artie
I just received my latest order from Hank. I like warm light, but I have to say that I did not expect E21A 2700K R9080 to be this magical.
Colors look perfect, and it does not look like a typical 2700K led at all. It looks pure white on a white wall, there is no trace of yellow. Even SST-20 2700K JA3, which is known to be below BBL, looks a little bit yellow. At first I was sure that I actually received E21A 3500K R9080 by mistake. Only after comparing it directly to SST-20 2700K JA3 was I able to convince myself that it really is 2700K.
I now have D4V2 flashlights with these warm emitters:
E21A 2000K R9050 (received today)
E21A 2200K R9050
E21A 2700K R9080 (received today)
SST-20 2700K JA3
XP-L HI 2850K T6 8B (received today)
I still like all of them, but E21A 2700K R9080 is by far the best. There is no comparison. I have Lee Zircon 802 and 803 minus green filters, but even with a filter none of the other leds look magical like this one does. Perhaps Lee Zircon filters are not suitable for very warm leds, I do not know. I use E21A 2200K R9050 with a Lee Zircon 803 filter, and it does make it look a little bit better.
I suspect the reason E21A 2700K R9080 looks the best is that it has the highest R9 and the lowest DUV of them all. R9 makes a lot of difference. You should definitely get it if you like warm light.
You should definitely get one in 4500K. I have a few Nichia 291B sw45k (also 4500K) emitters, which were being already praised for being a nice neutral tint, but in my opinion, that is too rosy, and even looks a bit rusty compared to E21A 4500K.
E21A 4500K is simply the best high power neutral tint, you can get currently. It is about perfect.
By the way, I am also expecting back 3500K into the available tint list, which is again a very good tint.
