Lumintop Tool AA 2.0 EDC 14500 AA Flashlight
M4D M4X October 6, 2020
Sofirn IF25A Led Torch Super Bright 3800 Lumen Anduril UI SST20 LED Flashlight with Rechargeable 21700 Battery Super Bright and multiple use.
Seeknite sure looks to be copying some of Convoys designs.
i already try to find out if its a OEM brand or something similar
The Seeknite ST03 picture looks exactly the same as a Manta Ray S21 flashlight that I’ve checked out, except different LED and UI.
I guess they all come from the same factory..
some are marked Convoy, some get another brand name
i ask
new review online!
www.youtube.com/embed/jLQF1ssqJG0
i showed the prototype a year ago ;)
i fixed the links
Also hadn’t noticed announcement of this model before.
It uses 3x XHP70.2 … so it would look like a competitor to the Haikelite MT03 TA Devourer, which also uses 3x XHP70.2, which also uses NarsilM and Texas Avenger driver. But maybe Lumintop’s build quality may be better? (MT03 TA Devourer claims “21000” lumens which is more of an exaggeration, whereas the GT3 specs indicate 18000 lumens, which might be possible in ideal conditions (high-drain battery + maybe if spring-bypass is needed?)
I wonder how the battery carrier tube looks like on the GT3?
So much mis/lack of information in the listing of the GT3 - says NarsilM, then says Anduril, says smooth reflector then shows an OP...
Would like to see the battery tube and if the button has a LED controlled by the firmware (EDC18's switch LED is not controllable by firmware).
That bunny button, if like the EDC18, could be stiff and prone to wearing down - not big issues, but they could have done better with the EDC18's button for sure.
If the GT3 has Anduril, I’ll want one. I have a big pile of flashlights I would like if they had Anduril, don’t want to add to that pile.
it has Narsil (neal added the anduril line because of the license i guess)
and teh reflectors are OP
