Found some no-oxidation grease at home depot
NOALOX 4 oz. Anti-Oxidant Compound
* Anti-oxidant *compound improves efficiency and service life Reduces galling and seizing on aluminum joints
For aluminum to aluminum or aluminum to copper connections
Use the Ideal NOALOX 4 oz. Anti-Oxidant Compound to improve the efficiency of aluminum conductor connections. This compound provides additional inner-strand and inner-conductor current paths.
Anti-oxidant and anti-seizing compound improves efficiency and service life of aluminum electrical applications
Suspended zinc particles penetrate and cut aluminum oxide
Provides additional inner-strand and inner-conductor current paths for improved conductivity and cooler connections
Reduces galling and seizing on aluminum conduit joints to promote good ground continuity
For use with pressure type wire connectors including screw-on, tap, service entrance and split-bolt
Pretty sure there’s still time. I just bought an orange one today off aliexpress and (who knows how accurate it is) the stock count said there were a few more available. (Allegedly getting to me by 11/15/2020.)
I think I’ve experimented with reflection behind my LT1 and haven’t noticed a big difference in the illumination in the area where the reflected light would go. What’s your experience with this device? Too bad he didn’t do a better job applying the reflective tape.
The tape doesn’t bother me at all and doesn’t noticeably change anything, but i can always change it out if needed at some point.
I use my LT1 a lot for night time reading and from what I can see, it allows me to use a lower output than normal, and prevents “wasted light.”
Honestly (and it’s still daytime here so I haven’t been able to thoroughly test), it seems way more efficient to use, if I don’t need 360 degree light.
Looks like a good way to walk around using the LT1 as an area light as well. Anyone that has ever watched a movie where they hold a 360 degree lantern up to see better should understand the fallacy of this, it puts as much light back in your face as you are getting from elevating the light… :person_facepalming:
