我是中国的手电筒制造商
Aircraft maintenance engineer.
I am re(aly )tired.
Flight Operations.
I work in a powerstation as a trade assistant. I may not be very smart but I can lift very heavy fings, especially with a crane or forklift.
Software Dev & DevOps in the field of retrofitting industrial equipment with new technology
Music Producer (formerly an Electronics Design Engineer).
Psychotherapist… But an engineer inside.
Mixing the two I do accurate formulations.
Retired.
Printing industry
Retired Oracle programmer. Now working full-time spoiling grand-daughter
What flashlights do you produce?
Physicist, technical writer, teacher (math and physics)
That’s a nice video and a very interesting and amazing building technique.
How is vertical alignment and adjustment done for the tilt ups—are any sort of optical tools needed (telescope, theodolite, etc) or can plumb-bobs and carpenter levels meet the task?
What are the dimensions of the concrete sections and how are they transported from the casting site, or are they poured on-site?
cheers
ps. long-haired beer-drankin’ crust-eatin’ pickup-drivin’ dumpster-divin’ rocket scientist
Thanks kennybobby. Concrete tilt ups have been around for a while. It’s been a popular building method around here for about 30 years or more.
Plastic packers/shims are placed on the footings using a laser level. If the panels are cast straight and square then there’s usually not much to adjust. Before de-rigging i check the edges with a long spirit level (carpenter’s level) and try use that to eyeball the edge right to the top. If needed (often) make adjustments to the packers to try and get it plumb. Not the most scientific way but there are many things at play. The granos can make it a challenge sometimes, the roof steel has a tiny bit of wiggle room for out of square etc… and the company is paying around a $1000(au) per hour for all the machinery and staff on lift day so safety and speed are key.
We have cast off site and had it delivered before but we rarely do it. Nearly all the panels you saw in the video would’ve been too big to transport. Unlike housing no two jobs are the same so the panels for each job are individually detailed. We might get a handful of panels the same size in a given job but it really all depends. There is a couple of standard thickness’ for them which, again, depend on some variables.
Any time Hope I was concise enough. I could ramble on :laughing:
M&M hired gun.
marketing and merchandising.
Unilever.
Procter & Gamble.
Warner-Lambert (now Pfizer).
right now, Honeywell.
Commercial fire alarm systems.
Retired theft investigator for large municipal utility. Largest recovery was $1.64M. No I won’t tell you how to beat your meters.
Service Manager for a national automotive chain. Basically run the shop and sell service repairs on customers vehicles.
WTH! Was that from one customer—how long was that happening to rack up a bill like that?
Heavy equipment product support.
For Australians here (pinkpanda3310 , grin) ; do you recognize WARATAH ?
