How does our addiction to lights rate ?? :laughing: :laughing:
The roof steel - cross bracing, parallel chord trusses. The panel eventually gets tied into the floor slab as well. I only say that because i’ve seen pics of a building that had a fire which collapsed some of the roof steel and all of the panels ( a couple of which were only connected at floor level, remained standing. The surrounding buildings blocked a lot of wind so they didn’t get blown over but still… 125mm thick, 7m tall and weighing 15-20 tons each….
We don’t need to worry about earthquakes. The Meckering Fault Line is a little ways out of Perth and is not very active. The vast majority of sites we work on are sand. We only encounter problems when we dig up stuff that was buried by man.
Waratah is a plant. Pretty sure it’s an aboriginal word.
Different cooked, tasting the same. We had a large industrial user on 3 fase high tension.
Visited by very specialised (high paid) metering guys. Suddenly the consumption is down by 33%.
Meter guy thinks( ? ): Okay. Meter dept thinks: Okay. Billing dept thinks: Okay.
Apparently nobody notices. Forrest Gump would have noticed, or Lassie, or Flipper, or Mr.Ed.
Untill Sourcing dept. (we) analysed sales (Peter Tosh: a man without a past is a man without a future).
The culprit was in the meters. A three fase system has three meters, and one meter was out of action.
Month after month the meter guy rapported: meter 1: nnnn MWh, meter 2: nnnn MWh, meter 3: 0 MWh.
There was no foul play (only lazy colleagues) but still we had a very hard time getting our money.
The client tried the oldest trick in the book: so sorry, but the books on that year are closed.
The following months were filled with happy days …… if you were a lawyer.
Fortunately our legal dept. reacted very swift …. and hired an outside man to handle the mess.
Much the same here. Meter reader looked at the meter, looked at the huge hole in the ground, many floodlights indicating 24hr use, winches operating, dirt conveyor filling trucks yet no consumption. He should have gotten the credit.
Some really interesting occupations represented here. Certainly a wide variety. And cool video pinkpanda!
Data Analyst here… systems analyst, programmer, database admin, whatever you want to call it. Was that at Caterpillar for many years. Now I work for an awesome agriculture technology company
Edited my post before and then deleted it by mistake instead of saving it, good you found it in time! Thanks for the info. The prefab panels are a really good way to get a building up and running way quicker than formwork. Probably cost more but I could see where commercial construction would love the idea of getting everything done on time with minimal delays.
