The FW3A firmware has the max regulated level at ramp step 130 of 150… so 21 clicks.
As far as I’ve heard, yes.
To help with figuring out this sort of thing, I created a product and firmware map called PRODUCTS. Also, in Anduril2, the version check function includes the build date and vendor/product ID to identify which exact firmware was used. So in the future it should be easier to get this info.
If I recall correctly, it’s one HOLD_TIMEOUT unit of time per step, and the firmware for that used a HOLD_TIMEOUT of 24 frames. Each frame is 16ms, so that’s 0.384s per step.
I see in the Anduril manual that the default stepped ramp is 7 steps between “floor” 20/150 and “ceiling” 120/150 (+ turbo).
Is this default setting the same on all Anduril lights? And are the 7 steps equally spaced?
Also, it would be great if manufacturers using Anduril could publish the expected brightness of each of the steps, as per “traditional” flashlights.
The same on all lights? No, the ramp values are different for each build target. The ramp values shown in the manual are only examples.
Equally spaced? Yes, sort of. It’s equally spaced in terms of ramp steps… but what that means in lumens depends on the ramp shape. There’s a tool called steps.py which can be used to calculate exactly which ramp steps it’ll use. For example:
About what manufacturers publish, I’m sure we’d all like it if flashlight companies would consistently publish accurate data about their lights… but that problem is way beyond anything I can fix.
Thanks for the quick reply. I was hoping that something would remove the guesswork at approximating the lumen output at each step, other than referring to published reviews, or buying an integrated sphere.
I don't bother. Just pick a similar driver and overall "heat index" of the light. I don't recall what the A6 driver is exactly - 2 channels or FET+1. If FET+1, then use a Q8 or D4 config setting.
I've just received my first light with the Anduril UI (an Emisar D4v2 with Nichia E21A LED).
I have read in details the Anduril manual, many thanks and congratulations to ToyKeeper for this incredibly versatile and powerful UI, and for the detailed manual and useful diagram.
I have set my light to the stepped ramping, with only 5 steps because I like flashlights with few brightness levels.
Moreover, in order to have a very low Low, I set the Floor level to 2/150. Thus I have a real moonlight mode, nice for night bathroom trips. But I have noticed that when turning the light on in moonlight mode (1 Hold) the LEDs do not light up immediately, but only after about one second. This makes me keep the switch depressed longer than I should, and the light goes to Level2, which is much brighter than moonlight and blinds me. Hence my questions:
Is this one-second delay normal (see other issue below)?
Is there any way to reduce the brightness difference between Level1 and Level2? I assume that increasing the number of steps would automatically allow this, but as said earlier I don't want too many steps.
On the other hand, I notice that when a battery check (3C) says 3.7V, both my Fluke multimeter and my Opus BT-C100 charger say 3.85V. Can the battery voltage measurement be calibrated?
Now a strange behaviour of the lowest level: if the light has been in one of the highest modes, and I ramp down (click, hold) to Level1 (Floor level), the LEDs turn completely off. But the light is not OFF: in fact the LEDs do light up at the Floor level, but only after being completely off for 15 to 30 seconds! The warmer the light, the longer this delay: 15s when the light is almost cool (High for a short time), 30s when the light is extremely hot (one minute on Turbo).
Both of my KR4s exhibit the same behaviour, it isn’t a fault. It is a limitation of the driver type which the vastly more knowledgeable Toykeeper has better explained before. By default the bottom of the ramp (smooth, not stepped) is set to 3 due to the driver.
I set mine to 2 around the house and back to the default level 3 on night time dog walks.
The issue with moon turning off is a side effect of the constant current power circuit. Instead of using a digital signal to turn on and off quickly, it uses an analog control voltage. And analog circuits are typically pretty sensitive to environmental factors, so it can behave differently depending on things like temperature and which level it was at a moment earlier.
Steps at the bottom end of the ramp don’t have great spacing on this driver, because the output resolution isn’t very high. It could work around that by repeating each ramp level quite a few times in the internal 150-step table, which would help the stepped ramp spacing… but then the smooth ramp wouldn’t look as nice. So there are tradeoffs. I’m hoping a future version of the hardware will add more resolution at the bottom end.
About voltage calibration, that was added in Anduril 2. It’s not in Anduril 1 though, so you’d have to reflash the firmware to get that function.
If it helps, the way I set up my D4v2 with E21A is:
Ramp style: smooth
Ramp floor: 1
Manual memory level: stepped ramp 2 of 7
Memory timer: 10 minutes (Anduril 2 only)
This gives me consistent and predictable output every time I pick up the light, defaulting to my most-used level. But it also gives me the flexibility of the smooth ramp, including moon. So it has some benefits of both ramp styles.
As for reaching moon from off without accidentally going through a bright level, what I find works is: Aim the light so I can see the aux LEDs. Hold the button. As soon as the aux LEDs turn off, let go of the button and turn the light toward what I actually wanted to see.
On most other lights, it’s easy to time the button release by watching for the main LEDs to turn on… but since this driver responds slower, I watch instead for the aux LEDs to turn off.
It mostly just means the attiny chip and other components don’t have very precise calibration from the factory. So some lights read high while others read low. That’s why I eventually added a calibration function.
While the light is running, it reads under whatever load it’s currently using. In battcheck mode, it stays mostly off, so the load is pretty low. However, it uses a rather strong lowpass filter, and the battery itself may take some time to recover after being used at a high level, so battcheck can take a couple readings to converge on a stable value.
I’ve done something similar, which allows me instant access to #1 my most-used level, #2 Moon, #3 High. No other UI allows this AFAIK, because they all allow only automatic memory (which I hate, I don’t want my most-used level superseded by a Moon or a High because this is what I last used).
But I chose to set Floor to 3/150, hence avoiding the LED extinction after going down from High to Moon.
A bit risky if you don't react quickly enough, and your next level after Moon is a bright one (e.g. few steps in stepped ramping mode). I think I'll get used to make a very short "Hold", hence going to Floor and staying at this level before the ramping up starts.
A nice addition to Anduril 2 (maybe it is already planned?) would be a third menu option for the Ramp Config Mode / smooth ramping: ramp speed adjustment. N clicks ==> N seconds between Floor and Ceiling when ramping up.
One more reason for me to plan a future upgrade. I've entered the Anduril world only a few days ago, and I already feel addicted, this UI is so great and configurable that I don't feel anymore like buying lights with a different UI (apart from tiny AAA or 10180 lights). I regret I haven't ordered the reflashing kit from Hank, together with the light. BTW, which lights (apart from Emisar and Noctigon) have a board compatible with this reflashing kit?
Here are the results of a few more measurements:
Very hot flashlight (1 min @ Turbo): Anduril: 3.3V going up quickly to 3.5V / Fluke 3.60V
After letting it cool down to allow the battery to recover: Anduril: 3.4V / Fluke 3.62V
After charging the battery, right off the charger: Anduril: 3.9V / Fluke 4.15V. Same values after a two-hour rest.
The latter value is surprising: I remember doing a battery check immediately when I received my D4v2 with a full battery, and Anduril measured 4.1V.
You are right, for some reason I thought that it use the same MCU…
Anyway I have A17-DD driver with attiny25, so at least swapping it for 85 should be easy
I don’t know if this is right topic for my questions, but it seems like, so here they are.
1) I got D4V2 with KR4 CC 5A driver (LED - Nichia 219c) and have noticed that it seems like main channel and FET are active together when FET is active (config file - cfg-noctigon-kr4-219.h) - why it is like that? I may be wrong, but shouldn't it be like FET only?
// don't turn off first channel at turbo level #undef PWM1_LEVELS #define PWM1_LEVELS 0, ... ,1023
2) I have compared config files for kr4 (cfg-noctigon-kr4.h) and original driver d4v2 (cfg-emisar-d4sv2.h) and found those difference, which makes me question why it's like this (exept differences in configs that I can undestand, like AUX LED in button, soft reset with button and so on - wich root cause are hosts possibilities)
D4V2: // stop panicking at ~30% power or ~1200 lm #define THERM_FASTER_LEVEL 105
KR4: // stop panicking at ~25% power or ~1000 lm #define THERM_FASTER_LEVEL 100 #define MIN_THERM_STEPDOWN DEFAULT_LEVEL #define THERM_NEXT_WARNING_THRESHOLD 16 // accumulate less error before adjusting #define THERM_RESPONSE_MAGNITUDE 128 // bigger adjustments
So, I see different thermal settings and the question is - this difference due to bigger kr4 thermal mass, or the driver itself? In other words, should I change them for my light like in original d4 config (remove them, so ones from fsm will be taken)?
