You should definitely get one in 4500K. I have a few Nichia 291B sw45k (also 4500K) emitters, which were being already praised for being a nice neutral tint, but in my opinion, that is too rosy, and even looks a bit rusty compared to E21A 4500K.
E21A 4500K is simply the best high power neutral tint, you can get currently. It is about perfect.
By the way, I am also expecting back 3500K into the available tint list, which is again a very good tint.
I was disappointed in my d4v2 2700k. It seemed greenish. It could be because this chart shows its duv being higher than the others; right on the bbl while the others are below it. However, i then swapped it for 3000k and didn’t like that either. The warm ones may just be too ochre. Next will be 2000+3500.
I concur that e21a 4500k is the best tint so far. That’s definitely the one to buy now, but when 3500k returns that will give people more options.
I’ve modded two of these new emisars and consider it easy. The hardest part is getting the 6 wires back through the center of the mcpcb afterwords, but they can be pulled out and pushed back in to make this easier. There’s a lot of extra room on them. You also need to solder the main wires cleanly so that the aux board fits back in (duh).
Side Note - I used a propane torch, 6’ vise and small hammer to straighten and re-bend my kr4 clip into a deep carry. It came out… as a deep carry. kind’ve off center and tarnished (the heat destroyed the polished look) but it worked great! i can share a picture if anyone’s interested.
Problem is, the heat weakened the metal and it broke, a couple of times. I fixed the break 2x but now its not worth it. I am debating doing it to my kr1 clip but i don’t have another clip backup after that.
Cant wait for the REAL deep carry to arrive in the store!
I have KR4 E21A in both 4500k and 3500k. Could not pick between them, would be like picking a favorite child. 3500k beautiful warm rosy tint. 4500k extremely “clean”, neutral, rosy but not overly pink like sw45k. These are my 2 most carried lights by far at the moment. Buy both if funds allow!!
The Ledil Angie optic is a great optic. For all the LEDs I have used it with it is FAR superior to the smaller quads. If you are going to obsess about ultra high CRI might as well have a better optic and longer runtime.
I don’t know how good 7-LED optics are, but a “D4SV2” could probably fit 7x E21A, because it is similar size to Fireflies E07 (but Fireflies E07 does not offer E21A as an option).
We would just need a D4SV2-sized 7.5A CC driver and a D4SV2-sized 7x E21A-suitable board for 7-LED optics.
Or maybe we could have a “D4SV2” mule with 32x or even more E21A.
Anyone with D4V2/KR4 Nichia 219C 4000k? I would like to know the tint. I have a Lumintop HL3A and a Convoy T2 with this led and they have a very good neutral tint, however the Lumintop Tool AA with the same led has more yellowish tint which I don’t like so much.
