I believe my answer will be a little like the above one, as I don’t have the LD10 to compare. If I had, I would do real comparisons, but I guess the best way to compare them without that is picking the specs:
TK16 3xOsram = 338m
Imalent LD10 = 247m
About taking the bezel out and reaching the lens / TIR / Leds? I just pressed the bezel against the hand or a glove and rotated the flashlight.
It was not glued. Once you have the bezel out, you’ll reach the rest easily.
If you are asking about the driver side, I didn’t dismantle it, but it has a screw that can be taken out eventually.
One day, the clip just broke apart and shot off the light. One of the arms on the clip that grips the light literally just snapped off. I wasn’t even carrying the light when this happened. It was sitting on a desk. The light was less than 3 months old at the time.
Apart from the crappy clip quality, it’s a great light.
I managed to take some photos above the MCPCB and you can see that below it it has a shelf.
I also took some others, with and without the glass lens, similar to your photo.
I wasn’t able to take the driver of its place. I guess the wires are very short, so I would have to unsolder the driver to take it out.
It is screwed in with 2 screws too, as show in the review post!
No glass lens >>>> With glass lens
Indeed a nice little light! I didn’t have any issue with the clip so far. I just wish it was deep carry from the tail.
I also would like that changing modes was a bit faster (as Olight), but it is not unbearable
Definitely one of the best, brightest smaller 16340s in the market! :+1:
Yup! Take the bezel out, take the lens, take the o-ring and then tap with the flashlight in your hand, with the lens down.
If you cannot remove it, try a toothpick or something pointy but not hard to alleviate the TIR on the sides. Then tap again.
It is not glued nor stuck, but the holes in the MCPCB and even the thermal paste below it may be hindering it from coming out.
Try the toothpick gently around the TIR, without much pressure
If you have a suction cup, you can also attach it to the TIR and try to pull it out!!
