I wish the UM25C could connect to PC via USB like the TC66C Or maybe I just need a USB-C to USB-A converter, and then use the TC66C.
sorry that it can only use Bluetooth to connect to PC and mobile phone
RD6006W feedback
Yes, this is a super device, its capabilities cover almost everything! I checked it in all modes,ripple at low currents of 40 mV, at 6A no more than 150 mV. In my opinion, it is very worthy, the adjustment accuracy from the factory is 1-2%
www.aliexpress.com/item/4000282551930.html
RD6006W feedback
Packed securely in a foam box with the original packaging with the device. I connected it to a 36 V power supply, everything works fine. Voltage, current limitation - everything is clearly regulated.
RD6006W feedback
Got my RD6006W running with 36V 5A PSU
(by the way, RD6018 will be released in a few days)
RD6006 customer review
product is as described exactly i highly recommend to buy,thank you so much
nice power supply!
you are welcome , have a nice day
RD6006W customer review
It arrived very well packaged, in a styrofoam box, the source is excellent, I recommend it professionally ...
RD6006 and DPS5005 DIY
RD6006: www.aliexpress.com/item/4000282551930.html
DPS5005: www.aliexpress.com/item/1000004290003.html
Show you a DPS5020 DIY Feedback
On the left side - 1. Temperature controller, with a remote sensor 2. ampere voltmeter - 5v to 10A - for USB and ARGB LED strips. 3. DPS5020-USB for everything else. Something like this. Excellent for this price!
RD6006 feedback
A wonderful laboratory BP is obtained. the module is already flashed with the latest version 1.32. While waiting for delivery, I prepared the Z-17 case, the power supplies used Mean Well at 48 and 12 volts connected in series.
RD6006 feedback
It's a very nice module! I'm very happy with the purchase, also i'd connected over wifi on Android, no problem at all, i'll keep testing it for further assessment.
the easiest DIY based on RD6006(what about the heat dissipation?)
RD6006W feedback
Looks very good. I have no objections to the quality of workmanship.
RD6006 feedback
fast delivered, good communications, well packed. better than PlayStation 5.
Delivery 26 days, matches the description, ordering a second time, excellent seller, I recommend.
RD6006W feedback
it is very high quality product. i love much. packet included backup smd 10A circuit breaker, temperature sensor and mini metal cable terminal. 6amper model is more sensitive. i recommend to buy 6a and 18a model.
