Vapcell lists a 1A-capable 10370 cell:
http://www.vapcelltech.com/index.php/List/index/cid/92.html
IFR (3.2V), LiFePO4.
yeah,a large number of H10 arrived,
Dennis - are you guys considering offering a 20350, or better still, a 21350 cell? Need a couple and only iJoy seems to have the 20350, all sources out of stock. The 21350 doesn't seem to exist but would fit an Amutorch E3S perfectly.
Ordered a pair of the T50 21700's! They look like the best performing 5000 mAh 21700 cell around.
Who makes the T50? Seems like an amazing cell.
Nomenclature might suggest a Samsung 50T. That’d be a shock to me but a welcome one.
Thank you very much for your advice
We’re also looking at 20350 batteries
Let me ask you what are the main uses of this battery? 21350 battery?Is there any equipment available for use
It seems that the market use is not big, if you go to order, there will be a lot of inventory pressure
Thanks
It’s the chicken or the egg kind of problem.
AFAIK there are 0 flashlights on the market designed for 20350 or 21350 cells because the cells are not readily available.
There are some 26350 that would be compatible. 20350 or 21350 cell may actually make sense in such light as long as it’s modern chemistry because the 26350 we’ve seen to date are underwhelming, especially when it comes to internal resistance.
Anyway, as of now you’ll sell very few cells.
Unless we manage to convince some 21700 light maker to introduce a shorty tube.
I believe that this cell format has as much potential as 18350. But for this to happen someone would have to go first - or 2 parties would have to go together.
Maybe some BLFer who has contacts with flashlight makers could talk to them about that?
EDIT:
I see that I actually forgot about 1 20350 light.
There is a fairly popular (in some circles...) light from Amutorch called the E3S, usually top item featured on their home page here. It's a triple compact light.
They can provide a 20350, so one does exist. However it can fit a 21350 - I know because I can remove the tailcap and insert a 21700 in with no problem.
So actually the E3S is a 21350 light with no battery in existence that fits. Instead a 20350 or 18350 can be used, or even a 16340 will probably work.
I got 3 of them: copper colored, purple, and blue.
It took a while for the 18350 to become popular but now it is. I believe (or hope) the same thing will happen with the 21350 based on the ever growing popularity of the 21700.
For example, Amutorch took their E3 light (21700 based) and cut the tube down to make the E3S - only likely other manufacturers will do the same thing going forward, since the 21700 is really the new 18650. Makes sense?
...on my way. ;-)
vapcell Dennis, I do have some contacts to flashlight manufacturers. Maybe we can share some thoughts to see what's feasible in terms of bulk size, prices and scheduled time? :-)
I see a lot of potential for using (high drain) 21350 batteries in some flashlights that already exist in 21700 size but also for ultracompact small-sized new flashlights.
Wow this 21700 T50 seems too good to be true!!! Who makes this cell? Is it on its way to Mooch or HKJ for testing?
Thank you very much. If there are battery sizes with market potential, we expect to develop these products and try to achieve the best performance
We have sent samples to HKJ for testing
Mooch will not test the T50 for the time being, saying that few people have asked to test the battery
Hello Dennis,
It seems, that for some reason, 21700 T50 batteries are gone unavailable in the Vapcell AE store.
Can you tell me, what happened to them? Stock shortage, or other reasons?
Not available for me either. Was hoping to order these soon
Hello Dennis,
Sorry, the stock limit is sold out
Waiting for next batch of goods to arrive
Ah, good, so it is just temporary
I was a bit afraid, that they would become unavailable in the same way, as keeppower 6000mAh (the only large protruding top high current 26650 battery).
Did a reseller buy a large quantity? Hoping these aren’t like the H10 14500s and unavailable for a long time.
